Comp Cams EndureX roller lifters?
Old Dec 19, 2006 | 09:39 AM
gkull's Avatar
gkull
Default Comp Cams EndureX roller lifters?
I'm going to buy a set of lifters this morning over at Summit. I'm willing to try something new. I Saw on the Comp web site lifters called Gen III made for NASCAR and some other type made for higher spring pressures.
I know Jim and a few others swear by these lower priced EndureX. What would you buy?
The SR cam they will run on is 248/250 110 lsa with near .700 lift
Old Dec 19, 2006 | 10:10 AM
shafrs3's Avatar
shafrs3
No experience here but I've read of other's interest in Isky's Red-Zones.
Old Dec 19, 2006 | 11:31 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've had good luck so far with the newer Comp pressure fed lifters. The main reaon I used them was they gave me a HECK of a deal on them when they were developing them. When I toured Comp last summer they showed me where they ahd recently changed the axle shaft to an even better one than mine have. Look for a dimple in the end of the shaft for the *good* ones. If you have them rebuild them, they automatically install the better shaft these days.
But if you look at the Isky Red Zones side by side...you will see that they use a much larger shaft than the Comp. Do a search on Norval's posts...he had a picture of them.
Isky is also coming out with a needle-less lifter. It uses a solid bushing in roller. Supposed to be $150 more than the Red Zones....but they say testing is showing 4 times the life at least.
Might check them out.
JIM
Old Dec 19, 2006 | 11:58 AM
gkull's Avatar
gkull
The Isky red zone are a bit much to buy from summit today.
ISK-37296LO180 $673.69
The comp cams is:
CCA-888-16 $503.39
Estimated Ship Date: Today
Brand: COMP Cams
Product Line: COMP Cams Endure-X Roller Lifters
Lifter Style: Mechanical roller
Lifter Link Bars Included: Yes
Link Bar: Vertical
Lifter Outside Diameter (in): 0.842 in.
Lifter Offset: None
Quantity: Sold as a set of 16.
Notes: Designed with extra oiling groove milled into the body for low-rpm street and marine applications.
These are what I have in my 383 right now. The ultra-lightweight Pro
CRN-13570-16 $509.95
Brand: Crane Cams
Product Line: Crane Mechanical Roller Lifters
Link Bar: Vertical
Lifter Offset: None
Lifters, Mechanical Roller, Vertical Link Bar, Chevy, Set of 16
The strongest, most durable roller lifters available.
Crane Cams mechanical roller lifters are the standard of the industry--they're racing's strongest, most popular roller lifters. Both Crane's standard design and ultra-lightweight Pro series are available. These lifters are precision CNC-machined for accuracy, and are the strongest, most durable lifters available for competition or serious street applications.
Old Dec 19, 2006 | 12:05 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
In a big block you could not pay me to run the Explode-X. I had a near failure and two friends of mine had massive failures. Maybe they have improved the design in the last few years. That being said, I have not heard of any problems with small block applications.
The bushing idea in the Isky's seems like a good idea long overdue.
Old Dec 19, 2006 | 12:14 PM
gkull's Avatar
gkull
John, I have been happy with the Crane Pros. I was going to watch the video and the download speed was like 30+ minutes. everybody must be getting it now.
I did see a video a few years ago of nearly glowing white springs in some kind of race motor. My blower buddy saw it also. He had several spring failures drag racing (9200 rpm in his 555ci KB) It convinced him to run the tilton pump and just fill the valve covers with oil just to cool the springs
Old Dec 19, 2006 | 12:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Gkul-The Cranes are decent, but most guys with a serious motor prefer the Crower sever duty or Isky red zone. Unfortunately they are both pricey.
Old Dec 19, 2006 | 01:09 PM
gkull's Avatar
gkull
The Crowers are about the same $500 price.
spacer
CRO-66200H-16
$529.99
Show All
Brand: Crower
Product Line: Crower Roller Lifters
Link Bar: Vertical
Lifter Offset: None
Notes: With HIPPO oiling system.
* Check to make sure this part fits your application
The best roller tappets on the market.
These roller lifters from Crower deliver 200 percent more life expectancy than competing brands. They feature crowned bearings and crowned outer races that greatly reduce lobe tracking.
To Comp Cams EndureX roller lifters?
