Rear axle fluid change- process ?
Old Dec 21, 2006 | 03:37 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by Durango_boy
Oh...a tip for filling. Leave the drain plug out as you fill...obviously, and when it pukes out of that hole...you're done.
Would it not be better to leave the fill plug out? Otherwise, you would have to roll the car over. Not a bad idea though. Would make suspension work easier.
Old Dec 21, 2006 | 03:39 PM
Durango_Boy's Avatar
Durango_Boy
I didn't meant he new drain plug...I mean the stock one up on the top. I guess it's a fill plug though...not a drain plug.
Old Dec 21, 2006 | 03:43 PM
Big2Bird's Avatar
Big2Bird
I know what you meant. Just still upset you took me off your cruise list.
Old Dec 21, 2006 | 03:49 PM
Durango_Boy
Don't feel bad...I'm not going to Montana either.
Old Dec 21, 2006 | 09:58 PM
chrisd0729's Avatar
chrisd0729
Originally Posted by C3 4ME
You can use a 12pt I think 3/4 inch socket on the square fill plug. That makes it easier to take out.
Maybe I'm looking at the wrong plug... I'm seeing a plug on the rear of the diff, angled off to the passenger side and has a red plastic tag reading "LIMITED SLIP" . I assume that's on the newer axles?
Old Dec 21, 2006 | 10:47 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
That would be the fill hole. This discussion deals with adding a drain plug on the bottom to faciliate fluid drainage.
Old Dec 22, 2006 | 12:06 AM
chrisd0729's Avatar
chrisd0729
Sorry for the confusion... I was quoting C3 4ME's note on a square fill plug.
Old Dec 22, 2006 | 10:27 AM
Durango_Boy
Could just be a difference of years.
