C3 Keyless Kit.
Old Dec 20, 2006 | 04:24 PM
Durango_Boy's Avatar
Durango_Boy
Default C3 Keyless Kit.
Do you guys think there would be a good market for a kit, containing everything one would need to convert a manual lock car to keyless entry? It would be pretty easy since I've done it before and know where to get everything. It would be simple and useful at the same time.
Thoughts?
I could become a vendor if I had enough orders....
Edit: MODS - I'm not selling anything with this thread...just gaging possible interest, and maybe I can help a few guys out in the future.
Old Dec 20, 2006 | 04:32 PM
vettenoir's Avatar
vettenoir
Sounds
However, right now I'm just happy when the key can unlock my passenger door
Time to the linkages ...again
Old Dec 20, 2006 | 07:42 PM
LittleJake's Avatar
LittleJake
You can find the kits on ebay for around $25.00, a lot cheaper than putting together everything in my opinion.
If you put a kit together I would be interested to see what materials you would use and the price.
Good luck!
Old Dec 20, 2006 | 07:51 PM
onaqwst's Avatar
onaqwst
if you can get one to work for my 77, i'm game.... last time i tried, i couldnt get a good angle of pull on it..... let me know..
b
Old Dec 20, 2006 | 07:54 PM
copter's Avatar
copter
I would think that a push button start would be cool.
Old Dec 20, 2006 | 07:58 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
b
This is the set up on my door, and it has worked flawlessly for a few years now.
Old Dec 20, 2006 | 08:05 PM
Durango_Boy
The problem I ran into was travel. The actuator wants to travel about a full inch, and the locking linkages move about half that when they moved from one position to the next.
Old Dec 20, 2006 | 08:10 PM
onaqwst's Avatar
onaqwst
was that just to unlock it?.... i'm looking for a door popper kit that releases the latch and kicks the door.... the door latch needs alot of force to engage.... i'm still up in the air with it
b
Old Dec 20, 2006 | 08:14 PM
SIXFOOTER's Avatar
SIXFOOTER
The thing I have not found would be a keyless entry kit that has a garage door button on it. I am one of those minimalist guys that can't stand carrying around a big azzed ring of keys and I want a keyfob remote to lock/unlock the car, arm the alarm and open the garage door. Got one of those around? Oh, it has to be Genie Intellicode compatible
Old Dec 20, 2006 | 08:29 PM
Kalway's Avatar
Kalway
So demanding!
However, that would kick serious *** if there was one. Come out here and install one of those on my car DB! You can use it as a marketting gizmo.
Old Dec 20, 2006 | 08:48 PM
VCuomo's Avatar
VCuomo
I'd be interested!
7t2vette - would you mind posting details of your setup? I've got a '72 also. TIA!
Old Dec 20, 2006 | 08:56 PM
7t2vette's Avatar
7t2vette
b
Yes, my set up was strictly for remote lock and unlock.
Originally Posted by VCuomo
I'd be interested!
Here is a link to a write up I did a few years back, it's in the archives at corvettefaq.
http://www.corvettefaq.com/c3/doorlocks/doorlocks.html
Old Dec 20, 2006 | 09:03 PM
spedaleden's Avatar
spedaleden
If you have an extra button on your remote. You can make that extra button activate your garage door. You need to find out who the manufacture is and you want to get a Garage door kit or they my call it a 1 channel receiver. If not you can find on ebay another keyless or alarm module. Tap the module into the garage door switch which is just looking for contact. Code the extra channel into the new reciver and you good to go. I have this set up for my sons car.
Old Dec 20, 2006 | 09:05 PM
spedaleden's Avatar
spedaleden
Remote start works great with Automatics that fuel injected. Carbs are tough
Old Dec 20, 2006 | 09:43 PM
Durango_Boy
I had a friend that tried a carbed remote start. It only worked after the car had been started that day.
I always wondered how the computer knows when to disengage the starter, and if it were trained to keep on it longer if more carbed cars would start.
Old Dec 20, 2006 | 09:52 PM
SIXFOOTER's Avatar
SIXFOOTER
Now why didn't I think about that? I got all that stuff laying around, Thanks!
Old Dec 20, 2006 | 10:34 PM
trw's Avatar
trw
I did mine. It cost about $50. I got a keyless for $25 with two relays and the power locks and hardware for about $20.
I love it. I think install is harder than finding the parts.
Terry
To C3 Keyless Kit.
Old Dec 20, 2006 | 10:40 PM
spedaleden's Avatar
spedaleden
Because the fuel is still up in the carb. We used to use a soleinoid that would prime the carb but some cars it worked fine others it would flood.
In regards to starter, The remote start would monitor tach, once it see 300 rpm it disengages the starter. If you had a little to much over crank, you could go into programming and take out a few miliseconds. I worked for Audiovox selling remote starts and alarms for years. Audiovox made the best R/S out there period. Audiovox and DEI were built at Nutek in Tiwain, and DEI always stole our ideas. Audiovox strengh was we owned the new car dealers business so we knew what was happening with the new cars so we could help the ma & pa store no problem because they didn't see the car till a year later.
I stop chitchattin
Old Dec 20, 2006 | 11:12 PM
Z-man's Avatar
Z-man
A carbed starter would need a separate unit to set the choke. That's why they are usually not available - plus there aren't enough carbed cars left to warrant the effort.
The EFI units sense the RPM to shut off the starter...
Old Dec 20, 2006 | 11:19 PM
Durango_Boy
Great to know...I will probably be putting in remote start too when I get my EFI system installed and running good.
