will one of these two bowtie crossmembers fit my 4 speed trans '77? i'm looking to find a lighter crossmember to bolt in place of the old stock (and heavy) one...but i think mine is not removable and here they're talking about removable crossmembers, am i right? any of you have one of these in a '77 4 speeds? thanks/Giu
You might try Keisler or a few of the other manual vendors and see it they offer a good tubular lightweight cross member for a '77 manual.
Sorry, we do not offer a replacement crossmember for the '77. We do have one for the '80-'82 but it was designed to accept the TKO. The rest of our vette kits use an adapter bracket that attaches to your existing crossmember.
Richard
Richard
Richard, thanks for jumping in. Since you do not offer one, can you shed some light on places to look, other vendors, and if something like that could be made easily for him?
Richard
Richard,
Do you sell any of the kit components individually? I'm putting a LS1/T56 in a 73 auto frame and I need to deal with the transmission mount issue. I suspect that your bracket and the modified crossmember might do the trick. The driveshaft and offset shifter might come in very handy also. Thanks.
Gimme a little time, I'm sure I can come up with something.
Rick B.
Well.... the truth is we don't sell the "proprietary" parts seperate from the kits(crossmember, sheetmetal etc...). I can help you with a driveshaft and shifter assembly though.
Durango boy, Panic: It just came to me... Try ATS for the crossmember
Don't know if they can help but they do carry crossmembers.
Richard
ATS? Thanks. Do you have a web address for them? I did a Google and didn't come up with anything.
Panic,
I'd bet the x-member for the 700r4 would be real close, with minor modifications it would work. However, if you've got a fixed x-member the modification would be much more involved. I'm putting one of these under my car to gain some space, I don't think there is much difference in the weight, however, I didn't weight the two to compare.
