Pre-oiling BB with a drill motor question?
Old Dec 22, 2006 | 04:11 PM
Big2Bird's Avatar
Big2Bird
George, Go rent the primer from Auto Zone. It has the correct piece to connect the oil passages, and the best part is it's FREE!!!!!!!!!!
Old Dec 22, 2006 | 06:52 PM
georgeculolias's Avatar
georgeculolias
Default I'm going to Autozone!
Thanks everyone for helping.
Old Dec 22, 2006 | 07:19 PM
68/70Vette's Avatar
68/70Vette
Although I think this thread is pretty well ended...
You can buy a oil pump primer from GM Performance Parts catalog. I think it costs $30 to $40. I bought mine from Scroggin Dicky (They are the forum sponsor that uses the logo SDPC). Works fine. It works with for either SB's or BB's. Did have to go out and buy one of the bigger electric drills to run the thing. I think to use the oil primer, if you use an electric drill, you need a 1/2 inch drill (7.5 amps). The Sears Craftsman 1/2 inch drill was a bit pricey. Anyhow, once I got the drill everything worked really well.
When I primed the oil pump/oil lines, the engine was on a stand. So I alternated oil pumping sessions by using a flywheel turner to slowly rotate the flywheel by 720 degrees.
Old Dec 23, 2006 | 09:29 AM
Finn Jensen's Avatar
Finn Jensen
This is the best way to do it. Twenty bucks will buy you a Proform priming tool. A cheap no-hassle investment.
I also mounted a simple external oil pressure guage to keep a check on things while running the drill, and turned the engine by hand a half-revolution at a time between priming. But this was fairly simple on my engine stand. In my case, it took about 30 seconds for the oil pump to take hold and circulate oil on a new GMPP crate engine. Assembly lube is not enough by itself.
