I've got the drill hooked up down the distributor hole onto the oil pump. It looks like a ton of oil is coming out through where the distributor drops through and I've got nothing coming out the pushrods. Is this right? Does the distributor block an oil return hole and cause the pressure to go up to the valve train? It's a stock 435hp engine...It worked before but I changed the cam back to stock and put in new pistons...Thanks for any insight.
You are right, there is a passage that is affected by the distributor. I can't recall the details, but if you use an old dist that has the gear removed and modified to fit into a drill, then you will see the normal oiling of the engine.
Gruntypants is right. You need the distributor body to block the oil gallery that feeds the lifters. You are just short circuiting the pump.
If you modify and use a old distributor you can get oil up through the push rods. I do this every year and it takes 5 or 10 minutes before all rocker arms are showing an oil flow and I also rotate the motor occassionaly while oiling.
Be careful you do not overheat the drill, take breaks if the drill starts to overheat.
spare distributor. So I guess the assembly lube will have to do. Thanks for helping!
I really would not skip the pre oiling. Remember and big block and small block distibutor is the same and any wrecking yard will have many cheap oil distibutors. Get one with a smash top part or anything broken.
Don't cut corners and just forget the preoiling. Take the extra time and modify a spare distibutor
NO! ... if this is a fresh build ... you REALLY need to either find a junk dist to make a tool ... or buy one that mimics a dist. Any junk chevy V8 dist will do! Even one that was cracked in a wreck. All you need is from just above the collar that sets on intake down to gear ... and grind the teeth off the gear. Don't risk a dry motor.
I have a junkyard distributor ($25) that I gutted and cut the cam off the mainshaft (hit the cam with a hammer and the brazing will break off). This makes the shaft fit right into a 1/2" drill chuck. Drop the distributor body into the block (SB & BB are the same), chuck the shaft up into a drill, and slide the shaft right down the distributor housing. The pre-oiling works great - don't skip it.
but sure don't want to buy a distributor and gut it. If it is that important someone should sell this...anyone know? It's not like there aren't millions of Chevys that have this problem. I bought the stock oiling tool...opps they forgot to tell me it wouldn't work!
It'll help if you pull the motor through at least 2 revs with a pull handle while you're spinning the op.
This doesn't make alot of sense, Pull the motor while spinning???
Yes it takes alot of time to pre oil. The drill will likely get hot and you have to give it a break of rish damaging the drill. Do it in stages until you get oil out of all 16 pushrods. I just watch that all valves are being coated with oil but remember to turn the motor over a few times so all bearings get oiled.
Remember rod bearings only get oil for 180 degrees of crank rotation so if you stop in a position where a rod gets no oil you have to rotate the motor over past this point. Most mains are only grooved in the top and that is the oiling part for the rods.
Before I fired up my engine in the spring I wanted to prelube it. I figured I would call a couple of bone yards to get a junk distributor. Some said they didn't have any distributors (hard to believe) and the ones that had them wanted like $40-$50. I found out it was cheaper to buy the tool; cost with shipping was under $20.
Some drills will be better than others. A 1/2", low speed drill works fine. It will spin about 500 rpms which is equivalent to about 1000 rpm engine speed (an engine running at 1000 rpm will make the oil pump spin at 500 rpm).
After spending $1000's on engine parts there is no reason not to spend $20 and 10 minutes of time to possibly prevent enginge damage.
Maybe it will if I explain why ... it's also because of the lifters ... each has a band on its waist ... that band acts as a passage ... the lifters oil in a sequential line ... when the band fully-aligns with oil galley hole (that happens as the lifter rises or falls in line) ... the oil circulates around its waistband and onto the next lifter in line ... so, if you pull the motor thru at least 2 revs ... you will have rolled cam thru 1 rev ... and aligned waistbands w/oil galley holes in sides of lifter bores. Pull thru 2 revs is good ... 4 to 6 is even better. Merry Christmas.
-edit- if you get a chance to see Joe Gibbs racing "wasp-waisted" lifter ... has a sort of hourglass profile ... much lighter ... and always aligned with oil galley that's perpendicular to & passes thru lifter bores.
