Body - hood alignment
Old Dec 22, 2006 | 11:09 AM
langg's Avatar
langg
Default Body - hood alignment
Hi everyone - Merry Christmas to all.
I installed a new hood on my C3 and the front edge is lower than the front panel. I notice that if I press down on the front panel, it will flex downward and align with the hood. Has anyone come up with a way to pull the panel in towards the metal reinforcement that crosses underneath? The metal does not contact the fiberglass on mine and I was thinking of trying to bond T nuts to the underside of the fiberglass. Possibly with some mat overlay to increase the area of the bond.
Any thoughts?
Lang
Old Dec 22, 2006 | 11:11 AM
Big2Bird's Avatar
Big2Bird
Have you tried shimming the hood hinges?
Old Dec 22, 2006 | 11:14 AM
LYLE's Avatar
LYLE
If it is loose the metal may be rusted as this is common and you need to bond on a new part.
Old Dec 22, 2006 | 11:15 AM
langg's Avatar
langg
Sorry, I should have also said: The sides line up from front to back. The corners are matching. The center is lowest.
Old Dec 22, 2006 | 11:35 AM
big_G's Avatar
big_G
Check the upper surround reinforcement/headlamp support bar. The bond may be coming apart.
To Body - hood alignment
