Rochestor Fast Idle Adjustment
Old Dec 22, 2006 | 11:43 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
Default Rochestor Fast Idle Adjustment
Hi, I have a 1970 350/300 hp coupe with Air conditioning and a automatic transmission, the Rochestor carb was rebuilt and the problem I have is during warm up the fast idle speed is up as high as 2000 rpm. What should the rpm be and is it the fast idle screw that I need to adjust.When the car is warmed up the rpm will drop to about 700 rpm. I have to play with the fast idle cam to get the rpm to drop to a lower rpm during warm up. I would think somewhere in the 1200-1500 rpm range, not 2000 rpm range. (Like trying to rev the old lady's motor when she's cold)See attached file
Old Dec 22, 2006 | 11:48 AM
a1sensei's Avatar
a1sensei
Yes, you can adjust it with the fast idle screw. I've seen instructions that say to set it that high, but there is no problem with setting it lower, you just need the car to stay running. God bless, Sensei
Old Dec 22, 2006 | 02:29 PM
lars's Avatar
lars
Just back the fast idle screw off to get about a 1000-1200 rpm cold idle - that's comfortable for most applications.
Old Dec 22, 2006 | 03:06 PM
JIMS1970VETTE
Thanks guys and a Merry Xmas and Happy New Year to All!!
To Rochestor Fast Idle Adjustment
