Power - Where it comes from
Modern cars do a hell of a lot better than that. Some produce over 2 horsepower per cubic inch. Where does that power come from?
To me, this is amazing. Especially considering that (1) they have to deal with emissions control, I don't, and (2) they are measured in SAE net horsepower, while mine is measured in SAE gross horsepower, making theirs look lower by comparison.
Some of the reasons I can think of include:
1. Turbochargers -- these add significantly to HP
2. Fuel Injection
3. Engine Management Systems, controlling timing and fuel --- seems to me a fine-tuning, not a huge power gain
I know I must be missing something significant.
If I change out my cam, intake manifold, exhaust headers, and other parts that might not withstand the higher torque, I can marginally improve my HP, maybe up to 400HP instead of 350... but certainly not 700HP (2 HP per cubic inch).
Don't get me wrong -- I totally believe "there is no replacement for displacement", and that the type of power I'm getting is raw, mean, consistant, and high torque. Still... I can't help but wonder. A lot has changed in 27 years... is there any good stuff that can be adapted?
Heads, roller cams, induction and fuel management pretty much in that order.
JIM
Like said before, heads are a huge part of it.
But I have to say, I'll take the sound of my small block over a variable valve timed rice rocket any day.
Actually, it's pretty commonplace to have small blocks with 700hp. Guys with twin turbos have ones putting out more than 1,000hp. You can easily bolt on parts to hit your mark...just like the auto manufacturers do.
Also, pay attention to the speed at which the hp of modern cars are rated and the size of the engine. For example, Honda rates its S2000 hp at 7,800 rpm. Since hp is based on rpm, the faster the rpm, the higher the hp. It's easy to rev a small engine to get high hp per cubic in. But the lack of torque makes it doggy on acceleration. So hp alone doesn't always tell the full story.
I was wondering if anyone had done turbos... 1000hp is shocking. I had no idea about the heads... my system is all old stock heavy cast iron stuff... do you think I'd do better to swap out my heads? and if so, for what?
At risk of going off of my own topic now...
My '69 coupe has seen very little use, but very little service as well, something I hope to change. Right now from the line, if I slam on the gas it slowly musters the strength to get moving, something I absolutely abhor. Once it's up to 20 or so, if I push down the pedal, the front end lifts up and it really pulls nicely. So something is clearly limiting my power initially... I'll have to rebuild and tune a lot of stuff to find out why. I did the timing (ala Lars paper), and am going to rebuild the carb sometime soon.
Worse even than the sleepy performance, the car seems to bounce all over the road. If I put on the gas a the wrong time, I might be pointed the wrong direction! Before I get any more power, I've gotta make sure the tires are pointed straight, and the suspension and handling are solid. I'm looking at a composite spring in the back, polyurethane bushings, gas shocks, soft front springs and thick anti-sway bars all around. Does that sound about right?
HP = TQ x RPM / 5252
The Fall 2006 issue of Engine Masters magazine has a great editoral about this.
Basically, to summarize, a good street engine using today's technology can make 1.2 to 1.3 lb-ft of torque per a cubic inch (1.3 to 1.4 for a race engine). So, on with the examples.
Lets say we have a great 327 motor and it makes 1.25 lb-ft per a cubic inch. That works out to be 409 lb-ft of torque at the peak. If we build it to peak at 5500 rpm, we get 372 hp. 6500 prm gets 440 hp and 7500 rpm gets 508 hp.
Now, lets say we build a 454 cube small block and make the same 1.25 lb-ft per a cubic inch. We now get 565 lb-ft of torque. 5500 rpm now gets us 515 hp. 605 hp at 6500 rpm and 700 hp at 7500 rpm. The 327 could make 700 hp but it would have to spin to 10,500 rpm!
Of course, all these numbers are based on good flowing parts and naturally aspirated. What flows well for a 327 would choke a 454. And, forced induction throws everything out the window.
Basically, what I am saying is that I don't care that an S2000 makes 200 HP at 8000 rpm or whatever. Torque is what you drive on the street and a well built small block is a lot more fun than any four banger.
