Died while in flight..where to start?
Old Dec 23, 2006 | 10:42 AM
mkflanagan's Avatar
mkflanagan
As a general rule a car has to have three things to run.
1.fuel
2.air
3.fire
One of these three things is missing.Check if you have fire on all plugs and fuel to the carb.Air is usually not much of an issue unless you car is sealed in a air tight chamber or something.
Old Dec 23, 2006 | 01:09 PM
JaxFl82's Avatar
JaxFl82
Is there a way to test the ignition module?
Old Dec 23, 2006 | 01:48 PM
wnaberacing's Avatar
wnaberacing
You can take it to your local parts store. Most of them have an ignition module tester. If it winds up being a fuel pump I have heard it's better to go with the pump out of an 84 vette instead. Not sure why. Just what I've heard.
Old Dec 23, 2006 | 01:49 PM
...Roger...'s Avatar
...Roger...
Yes -so you tested and you dont have spark?Do you have 12 volts to the distributor?
Old Dec 23, 2006 | 02:45 PM
jlaw68's Avatar
jlaw68
check the wires in the cap the go to the coil. i had one break about 6 months bad. if you have to ignition module checked have them test it 4 or 5 times to get it good and hot, that will let you know if its bad or not.
Old Dec 23, 2006 | 03:06 PM
jdp6000's Avatar
jdp6000
Check the obvious first...all the fuses including the ECM fuse. Try what someone suggested here...pour a little gas down each throttle body and see if it starts. If it starts its probably the fuel pump or fuel filter. If it doesn't its probably electrical...probably something to do with one of the modules (ther are 2) in the distributor or coil.
Only other thing that would shut off fuel supply would be a signal from the oil pressure sending unit. If pressure drops to zero its shuts off the fuel pump. Whats your oil pressure when cranking??
Jim
Jim
Old Dec 23, 2006 | 10:47 PM
JaxFl82's Avatar
JaxFl82
Default Thanks
Thanks everyone. I'm pretty sure I have enough to get a good start on figuring it out. I'll let you all know what i find out later in the week when i get at it. Thanks for taking the time to read and respond.
Merry Christmas and Happy New Year!!!
Old Dec 23, 2006 | 11:45 PM
paulywannafly's Avatar
paulywannafly
before you buy modules and other ignition parts make sure rotor spins when cranking motor . Have only seen it once but a timing gear that had
the fiber teeth torn off causes instant shutdown and bent valves . aftermath is no spark and no injector pulse not to mention motor that cranks weird
Old Dec 24, 2006 | 02:27 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i'm on the ignition bandwagon. check module and coil. did you try to pull a code?
Old Dec 24, 2006 | 07:27 AM
JaxFl82's Avatar
JaxFl82
No, didnt try and pull a code...but sounds like a good idea.
Old Dec 24, 2006 | 07:36 AM
DR.Jay's Avatar
DR.Jay
A faulty ignition module may not cause any codes to be stored.
Old Dec 24, 2006 | 08:55 AM
...Roger...
Dont forget the "prime pulse check"-remove air cleaner and turn key on and watch injectors for spray.With the coolant being cold you should get a good shot of fuel.Dont mean to sound like a stuck record but 50% of my "no start" problems with 1982s has been a fuel gauge that "lies".I always recommend putting a couple of gallons in to be sure because its difficult to see down into the tank with that little flapper and small opening.
Old Dec 24, 2006 | 06:29 PM
  #33
JaxFl82's Avatar
JaxFl82
Not at all DWncchs, I'll check that first...easy to do..dont have to take much apart...and best of all free.
Old Dec 24, 2006 | 07:04 PM
  #34
copter's Avatar
copter
I've got a new 84 fuel pump and everybody says you need an 85??
Old Dec 24, 2006 | 08:53 PM
  #35
wnaberacing
Why do they say use the 84-85 pumps? Do they build more pressure or what?
Old Dec 25, 2006 | 01:09 AM
  #36
coinwasher's Avatar
coinwasher
module would be my bet just had to put one on my 86 chevy shortbed it gave no notice and the motor was dead.
Old Dec 25, 2006 | 11:16 AM
  #37
copter's Avatar
copter
The 85 puts out more pressure and I think the 84 is the same as the 82?
Old Dec 25, 2006 | 02:59 PM
  #38
jdp6000's Avatar
jdp6000
85 puts out about 40 psi. The 82-84 is the same and only puts out 9-13 psi. Crossfire motor needs constant fuel pressure between 9-13 to operate. The 85 pump guarantees enough flow. Car is more responsive. Idle is better.
Jim
Old Dec 27, 2006 | 02:51 PM
  #39
coinwasher's Avatar
coinwasher
Ok, so what was the problem? Did you get it fixed?
