Died while in flight..where to start?
Old Dec 22, 2006 | 09:15 PM
JaxFl82's Avatar
JaxFl82
Default Died while in flight..where to start?
Any suggestions are very welcome. The other day on the way to work my stock 82 died while I was driving. I was getting along about 50-55 mph and the engine died. No bucking or anything, engine just quit running. It was early morning and I had the lights on. Nothing electrical shut off that I noticed. Felt like I either lost fuel or fire. After I coasted to a stop everything still had power. Car cranks strong but wont run. I'm thinking either the fuel pump or maybe something like the ECM? If it is one or the other, what's the best way to test either? Any other ideas on where to start investigating? Thanks in advance!
Old Dec 22, 2006 | 09:17 PM
Fevre's Avatar
Fevre
First check for spark and fuel; if no spark check your ignition module, should be able to get it checked free at the local chain parts store.
Old Dec 22, 2006 | 10:29 PM
...Roger...'s Avatar
...Roger...
Does your fuel gage show 1/2 tank? I have run into a bunch of 82s that show 1/2 but really are empty.If you just put gas in recently then disregard this post.
Old Dec 22, 2006 | 10:30 PM
Big2Bird's Avatar
Big2Bird
I would start with the fuel pump.
Old Dec 22, 2006 | 10:50 PM
moosie982's Avatar
moosie982
When my 80 L82 was on the road and I was able to enjoy driving it one time I was cruising along @65/70 MPH and the motor just stopped running, being late to a kiss the Hog contest I left it on the side of the road to have it flatbedded home later. When I got home I determined it had and was getting fuel but couldnt find where it was getting any spark, took the dist. cap off and saw that the rotor had a hole burnt in it, from what,,, I dunno, put a new rotor and cap on it and it fired right up, ran perfectly. Check yours,, ya never know,,,Peace,,,Moosie
Old Dec 22, 2006 | 11:02 PM
JustForFun's Avatar
JustForFun
im going with fuel pump, or....fuel pump relay
Old Dec 22, 2006 | 11:10 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
You said "No bucking or anything, engine just quit running" does not sound like gas it is probably something in the distributor like Fevre said your ignition module, or a wire came off or broke somewhere else. After you check the distributor look for a wire that might of got burnt in to by the exhaust or something like that.
Old Dec 22, 2006 | 11:13 PM
JustForFun's Avatar
JustForFun
ill take 2nd chance guess....ECM fuse
Old Dec 22, 2006 | 11:19 PM
Gary's 1977 Vette
It almost has to be electrial
Old Dec 22, 2006 | 11:59 PM
Steve COSD's Avatar
Steve COSD
If the car will run for 10 to 20 minutes before it dies I would check the ignition module that is inside the distributor. Heat will cause the module to be defective until the car cools down and will start once again until it gets hot again.
Good Luck
Steve
Old Dec 23, 2006 | 12:21 AM
...Roger...
At some point you had high resitance to ground through the plugs,plug gap,wires,cap or rotor.Once the high coil voltage jumped to the dist. shaft instead of going to the spark plug it started a carbon trail through the rotor.Then its just a matter of time until it burns a hole.Easiest path to ground.
Old Dec 23, 2006 | 12:46 AM
C3Bob76's Avatar
C3Bob76
I would have to cast a vote for ECM as well. I've had this happen to me on two other cars, both GM ECM modules, and both times it quit without warning. No sputtering, missing, nothing. Running one second and dead the next. Luckily it's an easy, cheap fix. Not 100% sure of course, but I wouldn't feel I had steered you wrong if you went out first thing in the AM and purchased a replacement based solely on my input.
Old Dec 23, 2006 | 02:03 AM
Z-man's Avatar
Z-man
Fuel problems usually cause at least *some* sputtering before they quit. Electrical is usually the problem when the engine quits instantly...
Old Dec 23, 2006 | 02:07 AM
luerja's Avatar
luerja
why don't you put a little fuel down the carb and try cranking it over.... if it starts and then dies then you know it is the fuel... or at least spray some starting fluid in there and crank the engine.
that may find or eliminate one of the causes of your problem.
JIm
Old Dec 23, 2006 | 07:45 AM
...Roger...
A fuel injected engine just stops ! No sputtering.
Old Dec 23, 2006 | 08:09 AM
ghoastrider1's Avatar
ghoastrider1
hook a timming light to it ..or go to auto zone and buy a cheap sparkplug wiretester thingy,,either one should tell you if your getting spark.Yea,and pick up a can of ether...that will tell you if its a fuel problem. cheap diagnose..pia sometimes to find and fix.
Old Dec 23, 2006 | 08:33 AM
JaxFl82's Avatar
JaxFl82
Default Thanks for the ideas
Thanks everyone much for the ideas...I'm working this holiday weekend so I hope to get under the hood about tues.
By the way, am I wrong in thinking that with the key on I should be able to see gas coming out of the injectors into the throttle body if I have the breather off and someone steps on the gas?
To Died while in flight..where to start?
Old Dec 23, 2006 | 08:34 AM
vvette390's Avatar
vvette390
If the car starts with ether or starting fluid, DON"T OVERDUE IT! The ether strips the oil from the upper cylinders immediately and you'll get galled rings and cylinders within a very short period. I vote for electric, but I am an old carb guy...good luck..just be patient and methodical
Old Dec 23, 2006 | 08:38 AM
...Roger...
When turning the key on after its been off for awhile you should get a 2 second spray.The gas pedal wont effect it until is starts.
Old Dec 23, 2006 | 09:37 AM
BKbroiler's Avatar
BKbroiler
I would check for spark first. If none, remove distributor cap. If everything looks normal, change the module.
