Edelbrock 2101
Old Dec 23, 2006 | 01:57 PM
DO2G's Avatar
DO2G
Default Edelbrock 2101
Is the edelbrock 2101 Intake Manifold a direct cross for a 1978 L82 with the original carburetor? Does it have the choke openings on the side and everthing else from the original except the EGR?
Old Dec 23, 2006 | 03:46 PM
Little Mouse's Avatar
Little Mouse
Just looking at a picture of the 2101 in there catalog it has the place to mount the
choke coil spring.
Old Dec 23, 2006 | 04:00 PM
Big2Bird's Avatar
Big2Bird
http://www.edelbrock.com/automotive_..._sb_perf.shtml
Take a look.
Old Dec 23, 2006 | 05:37 PM
3rd_Vette's Avatar
3rd_Vette
When I did my crate motor, I was going to use the 2101, but the guy at the parts house talked me into the 2701 for better performance and HP. I have an electric choke, the same as the stock Quadrajet on the Edelbrock 1406 Carb. In my opinion, go with the 2701. I have no regrets, except the additional power! It also all fit under the stock hood with the Edelbrock drop base air cleaner with just as much clearance as the stock air cleaner. Also, using the Edelbrock carb, no adapter plates between carb and manifold.
Old Dec 23, 2006 | 05:56 PM
Glassbowtie77's Avatar
Glassbowtie77
Everything matched up fine on mine, except there is no provision for the EGR valve.
Old Dec 23, 2006 | 07:34 PM
C3 4ME's Avatar
C3 4ME
Supervette, PM sent.
To Edelbrock 2101
