I TIG all my aluminum stuff - no MIG on aluminum. The 6000-series welds really nice, regardless of form - 6061-T6 or T651 is very weldable. The only alloy that is problematic is the 2000-series (2024-T3 aircraft stuff) - it tends to crack out pretty bad, and should not be welded.
When welding dissimilar thicknesses, just watch the heat input into the thinner material, V-groove prep the thicker material so you get a little more punch and heat into it rather that putting all the heat into the thinner stiff. But you shouldn't have any trouble with the 1/4" - that's a lot of thickness, and you won't blow through that unless you really punch it. You'll enjoy it - have fun!
There was no way to get a TIG torch in between the runners in this instance. Lincoln and Miller both say aluminum can be MIG welded.
yes MIG on aluminium although it works much better with either a pulse mig machine or at least a spool gun so the wire doesn't clog up the drive wheels and/or hose.
As for the map, indeed mount it on the firewall and use a semi hard plastic line or some rubber that you KNOW won't collapse. If you have a collapsing hose you will get all kinds of weird iddle and off idle symptoms from the hose pinching and opening up.
In 81 & 82 the map was positioned next to the brake footwell area on the firewall.
Yes, it can - it just doesn't look as nice as a GTAW weld. But if you can't get the torch in there, you need to use the process that will get the job done - I agree.
Yes my MIG welder requires a nylon sleeve in the torch hose and I need to keep the hose fairly straight. Also .035" wire, the .030" wire will just collapse and create a rats nest just after the feed roller.
