Tachometer Filter
Old Dec 27, 2006 | 07:47 PM
goathearder's Avatar
goathearder
Default Tachometer Filter
Hey All,
I am pretty sure my tachometer filter is toast and instead of spending 60 bucks for one, i would like to try and make one. I found the following info
http://groups.google.com/group/alt.a...f47fc359ccfad6
But I am not super electrically minded so can anyone convert that into a standard wiring diagram for me? I would love for this to cost 5 bucks and some time rather than 60 bucks.
Old Dec 27, 2006 | 10:10 PM
carriljc's Avatar
carriljc
Default there used to be a schematic on the forum...
I went and looked for it, but couldn't find it. Anyway, I found the following on the net.
I made one from the schematic on the forum, I don't remember if it was like this one or not, but it worked. It only cost me like 2 bucks in parts from Radio Shack and I had parts left over.
http://www.fieros.de/en/articles/tachfilt.html
Old Dec 27, 2006 | 10:33 PM
Artsvette73's Avatar
Artsvette73
Try www.egauges.com $20.00 works good. P/N sn20
Old Dec 27, 2006 | 11:30 PM
lucky76's Avatar
lucky76
Originally Posted by goathearder
Hey All,
This is my tach filter mounted on my 76's intake manifold, see arrow.
Diagram of parts in tach filter. X plugs into distributor, Y connects to connector going to tach. Gound is the case grounded to manifold.
Four parts other then the case, 5.6k and 10k 1/2watt resistors, a .10mf and a 100pf capacitor.
Also I don't know where I got this but it's good.
(Below from unknow source)
I think its unlikely, but possible the tach filter is the source of your problems. A change of Tach filter has often helped when the tach didn't work at all because the filter was open circuit. I don't recall too many cases of an erratic tach being fixed by a filter change (in the last year that I've been watching). Try putting in a quicky filter with R2=10K and C2=100nF. And yes I mean just the two parts. Its so close to the "real" filter that If that doesn't fix it, a new filter won't either.
Hope this helps.
Lucky
Old Dec 28, 2006 | 11:27 AM
goathearder
Awesome guys! That is just what I am looking for. I am pretty sure it is the filter cause when I bypass it, the tach works just fine. Looks like I am headed to radio shack tonight.
Hey CarrilJC, when you make yours, how did you house it? Did you wrap it in electrical tape or put it in a tube or something?
Old Dec 28, 2006 | 01:41 PM
carriljc's Avatar
carriljc
Default I wrapped it in a large tube of heat-shrink...
By the way, I found the thread which does a really fine job of describing what you need to build this thing. This is how I built mine, and I also remember having the question about the "microfarad" vs the "millifarad".
http://forums.corvetteforum.com/show...ht=tach+filter
Old Dec 28, 2006 | 02:12 PM
goathearder
Sweet! This forum is a wealth of info. Looks like I will be headed to radio shack tonight. So much better than having to spend 60 bucks : )
Old Dec 31, 2006 | 01:10 AM
goathearder
It worked!!! Took a few tries and finally my multi-meter but it worked!
Thanks again for the help guys.
John
Old Dec 31, 2006 | 12:44 PM
RadicalPursuit's Avatar
RadicalPursuit
Default Lack of filter
After reading this thread, I checked my car. I can't find a filter. What are the repercussions of having a filter? My tach is working fine at the moment.
Old Dec 31, 2006 | 08:55 PM
Kilroy1024's Avatar
Kilroy1024
The tach filter is a radio noise filter to stop ignition noise being taken into the cab area where it can be picked up by the radio.
Lucky76's suggestion of using only the two parts is correct. It should be more than adequate.
To Tachometer Filter
