distributer question
Old Dec 28, 2006 | 06:14 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default distributer question
What limits the centrifugal weight travel?
It seems to me that if you want 12 degrees of initial timing and then another 24 degrees of advance there has to be a stop of some kind.
What happens if you need 14 degrees of initial and 32 degrees total?
Old Dec 28, 2006 | 06:57 PM
Gordonm's Avatar
Gordonm
On a stock dist there is a pin that fits into a groove. Tough to explain but the pin is only allowed to move so much by how long the groove is. Some different plates had longer grooves or slots is a better term.
Old Dec 28, 2006 | 07:05 PM
Guru_4_hire
Cruise-In V Veteran
Where is this slot?
Old Dec 28, 2006 | 07:30 PM
gerry72's Avatar
gerry72
Pull the rotor off your distributor, remove the two springs you see under the rotor, then lift the two "arms" off the advance plate and you'll see them and everything else that will make it perfectly clear.
Old Dec 28, 2006 | 07:44 PM
Guru_4_hire
Cruise-In V Veteran
Ahhh I see it. Are there a variety of little rubber bushing thing around the pin, that limit advance.
Old Jan 11, 2007 | 10:52 PM
Lotus76's Avatar
Lotus76
I have an aftermarket HEI off ebay. I can only get 10 degrees of mech advance (I should get 20 degrees) no mater what springs I use.
With light springs I get the advance quicker but no more.
can I adjust or mod this "slot" to gain the rest?
Old Jan 12, 2007 | 08:11 AM
jnb5101's Avatar
jnb5101
remember that 10* distributor advance is 20* at crank. where are you measuring?
Old Jan 12, 2007 | 11:29 AM
Tom454's Avatar
Tom454
Yes.. some rubber, some steel, some brass.
Old Jan 12, 2007 | 01:41 PM
stingr69's Avatar
stingr69
The old school '74 and older points style distributors use a pin that travels in a slot. The autocam is weded to the end of the distributor shaft so it is not removable. You can add bushings to the pin or modify the length of the slot to get the right amount of centrifugal advance you want.
The 75 and up HEI centrifugal mechanisim works a little bit differently. The autocam where the weights slide against is removable. You will need to replace the weights and the autocam plate in order to get more centrifugal advance if your stocker does not have enough mechanical advance. Not all kits work right. The one I used was from Pertronix and it works pretty well. It is a drop-in that has something like 21 or 23 degrees designed into it (I forget the exact amount) so you can run more initial timing. I like the recurve part of the kit but I am not sure how you get one without buying the whole HEI upgrade package. Maybe someone else manufactures it for them?
-Mark.
Old Jan 12, 2007 | 03:07 PM
Tom454's Avatar
Tom454
-Mark.
I've been rebuilding these for about 35 years and all of the ones I have worked on have a replaceble bushing... rubber/plastic from the factory.
Can you clarify?
Never mind. I just re-read your post... the cam is welded.... yes... not the bushing... my bad.
Duh.
To distributer question
