One headlight opens
Old Dec 28, 2006 | 10:53 PM
spanishsilver's Avatar
spanishsilver
Default One headlight opens
and one doesnt. I have replaced the actuator motor and the relay. When I pull the headlights up and then go to close them with the headlight switch they both close. When I go to open them the left one opens and the right one doesnt. I can open and close both with a vacum pump manually. I have inspected all the hoses and there are no blockages or holes. Where do I go from here? Any ideas guys. Thanks
Old Dec 28, 2006 | 11:15 PM
Big2Bird's Avatar
Big2Bird
Where did you get the parts? I had the same problem with Eckler's repops.(Defective).I sent them back and bought new Delco units from Rik's. Problem solved.
Old Dec 28, 2006 | 11:21 PM
spanishsilver
Bought them right from GM at my local GM dealer.
Old Dec 28, 2006 | 11:35 PM
Durango_Boy's Avatar
Durango_Boy
You have a vacuum leak somewhere. You'll have to get a diagram of your vacuum system, and check EVERY switch and junction. The switch has vacuum, and the gate switch. The coolant tube to the heater core has a vacuum operated valve, and there are vacuum tubes going to the HVAC controls in the cab. Check there, and at the firewall where they go through. Check everything and I think you'll find the problem. Check the check valve at the brake booster too.
Old Dec 28, 2006 | 11:39 PM
Big2Bird's Avatar
Big2Bird
How are the bushings on the headlight assembly.? Does it move freely or bind?
Old Dec 28, 2006 | 11:40 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
www.corvette-101.com
Nice little vaccum troubleshooting guide should help out some.
spanishsilver
Just looked at the left actuator. Dust Boot is ripped so would this cause the right side not to come up and only close?
Old Dec 28, 2006 | 11:43 PM
spanishsilver
It takes a lot of vacum pressure to oipen up right side. Could it be that I have to lube up all the spings and bushings?
Old Dec 28, 2006 | 11:57 PM
Big2Bird's Avatar
Big2Bird
I had a few bushings that were disintegrated. Replacing them helps. Sounds like it just is too much work for the car's vacuum, but the pump has more . Check the forum search engine. I am sure there is a post on re-building these assemblies.
Old Dec 29, 2006 | 09:57 AM
spanishsilver
I am going to try to replace the bushings to start. I also am going to take out the whole assembly and clean and lube it. Ill keep ya posted.
Old Dec 29, 2006 | 10:17 AM
Durango_Boy
Good luck. I hope that works out. I still think you have a small leak. I had two small leaks, and my right would only go up after I let the car idle for a few minutes and built up the vacuum.
Old Dec 29, 2006 | 11:16 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Probably a seal...a bad dust boot wouldn't do it.
Larry
Old Dec 29, 2006 | 12:53 PM
Durango_Boy
Just curious, what's the system vacuum at the front by the vac tank?
Old Dec 30, 2006 | 10:59 AM
spanishsilver
Before I went to work yesterday I checked everything with car running. Took hoses off one at a time on the actuator relay to check for vacum from actuator. There was vacum on each accept the open port on the actuator. So I took the hose from the opening side of actuator cannister and connected to the close side of relay. Low and behold the headlight popped up. Connected all hoses back to normal ports and the headlight went down. So its not the bushings. It seems to be the actuator relay purchased from Ecklers. When I get back home I will take it out and check for blockage on the relay.
Old Dec 30, 2006 | 01:47 PM
Durango_Boy
I know it's a pain, but switch the two actuators, and try the headlights again. If the problem changes sides then you know what the problem is...and you'll be very good at changing out the actuators.
Old Dec 30, 2006 | 02:07 PM
Glassbowtie77's Avatar
Glassbowtie77
I would buy some longer vacuum hose and run them to the opposite sides instead of pulling the actuators out, switching them, and putting them back in, that's a real PITA in my opinion. Then if the problem changes sides you know what you have to do and only do it once.
Old Dec 30, 2006 | 02:47 PM
spanishsilver
Are you talking about switching the actuator canisters or actuator relays. Thanks
To One headlight opens
Old Dec 30, 2006 | 02:48 PM
shashi27's Avatar
shashi27
Check to see if the resevoir tank is blockedwith crud in the outlets. Worked for me and I am no longer blinkie.
Old Dec 30, 2006 | 02:50 PM
Big2Bird's Avatar
Big2Bird
Old Dec 30, 2006 | 03:05 PM
Durango_Boy
I meant the new ones you bought, and I didn't even think about changing just the vacuum. I feel like a azz now.
