Found another use for the LM-1....
Old 12-29-2006, 06:14 PM
69monzaredbigblock
69monzaredbigblock's Avatar
Default Found another use for the LM-1....
This may be old stuff to some, but today I used my LM-1 to check for those pesky vacuum leaks. I disconnected all my vacuum accessories except the vacuum advance can and took a reading at idle from the LM-1. I connected the hoses back and was shocked to see how much the numbers changed. I found a leaky headlight valve and a leaky connection at the heater control panel. With a pair of clamps it's easy to clamp off the hoses, read the LM-1 and see where the problem is! Fortunately these leaks didn't seem to screw up my carb tuning.
Old 12-29-2006, 06:55 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Interesting. If you had it set up correctly with the vacuum connected, I am guessing that the car ran rich with the vac pinched off. Just trying to figure out how you learned.
Old 12-30-2006, 09:19 AM
69monzaredbigblock
Exactly right. With everything disconnected I adjusted the idle mixture to an AFR of 14. With everything hooked up my AFR went to 17. As I pinched off the leaking hoses/devices you can see an immediate change in the meter back down to the 14 setting.
Old 12-30-2006, 09:32 AM
Gordonm
Gordonm's Avatar
I don't think I have any leaks but this is an easy check.
Old 12-30-2006, 09:39 AM
mkflanagan
mkflanagan's Avatar
May I ask what an LM 1 is?
Old 12-30-2006, 09:41 AM
Jud Chapin
Jud Chapin's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
My thoughts exactly!
Gordonm
Gordonm's Avatar
You certainly can. It is an air fuel meter used to tune in your carb. It uses a heated O2 sensor in the exhaust pipe and measures the amount of oxygen in the exhaust. Very useful tool for tuning your carb.
Old 12-30-2006, 09:46 AM
Jud Chapin
Jud Chapin's Avatar
Thank you!
Old 01-01-2007, 08:52 AM
billla
billla's Avatar
St. Jude Donor '14
Default Innovate link
http://www.innovatemotorsports.com/products/lm1.php
To Found another use for the LM-1....
Quick Reply: Found another use for the LM-1....
