Distributor Set-up
Old Dec 29, 2006 | 08:18 PM
JimT's Avatar
JimT
Default Distributor Set-up
I'm having trouble with the timing on my newly purchased '72 Stingray. At idle (700rpm) the car starts great, runs great, etc. The problem - my timing is set at between 16 and 18 degrees BTDC. If I drop the timing to the recommended 8 degrees BTDC, the car will idle, but will not restart, or, if placed in gear will stall.
The previous owner had removed/replaced the distributor and I think it is one gear tooth off. Can that be? If the distributor is off one gear, can you adjust the timing to match the error? That looks like what I have. Any thoughts?
Old Dec 29, 2006 | 08:21 PM
lars's Avatar
lars
Having the distributor installed one tooth off has no effect on timing. It only affects the clocking of the distributor relative to the engine once you've set the timing.
Initial timing is pretty much irrelevant - you need to set up total timing to 36 degrees and take whatever initial you get. There is nothing wrong with initial timing in the 16 to 18 degree range as long as total is at 36. 18 degree initial is a great spec for a performance engine with a little bit of a cam.
Old Dec 29, 2006 | 08:22 PM
jotto's Avatar
jotto
Can you get the timing set so its at 36deg all in by around 2800rpm? If so..wouldnt worry about base timing too much. You want to get it set at 36deg by around 2800rpm with vac advance disconnected and plugged.
This should get you best performance.
Check out the sticky up top with regards timing, very informative.
Old Dec 29, 2006 | 10:57 PM
marshrat99's Avatar
marshrat99
with everyone above. Lots of things will make the timing appear "different". Start trying to get where Lars recommends. If you can't achieve the timing recommendations, then first start looking for worn dist advance, dist gears. etc or possibly vac leaks. I'm with Lars that too many folk think that they have a carb problem but it is really a timing related issue. I also have had the outer portion of the balancer slip that appears to show an out of timing problem but which is not actually.
To Distributor Set-up
