hooker sidepipe ?
Old Dec 30, 2006 | 09:33 AM
dmaaero's Avatar
dmaaero
Default hooker sidepipe ?
my hooker sidepipes just came in and i noticed right and left side look different from the head flange to the center of sidepipe flange the drivers side measures 24 inches and the passenger side measures 21 inches maby i'm wrong and i hope so but wouldnt they both need to be the same ? 74 is the year there sitting side by side on the ground right now and 3 inch differance is quiet noticeable
Old Dec 30, 2006 | 10:33 AM
Duke94's Avatar
Duke94
I just tried to get a quick measure of mine (on the car) and they appear to be about the same length side to side. It was not easy to get an acturate measure, but they were no where near 3" different. Mine is a 78'. Might be worth a call to Hooker before you start.
Old Dec 30, 2006 | 11:08 AM
1fastC3's Avatar
1fastC3
my passenger side tube is shorter than the driver side to account for the passenger side of the engine 2,4,6,8 cylinders sitting closer to the firewall than the 1,3,5,7(driver side) with it all bolted up and on the car you shouldnt notice a difference, also have you bought some low restriction inserts or did you get the hookers, also if you havent ran it with open pipes you oughta try it at least once, sounds awesome but after a while your hearing will start to go. either way good luck.
-alex
Old Dec 30, 2006 | 11:41 AM
WESCH's Avatar
WESCH
Hi
Pax side is shorter all over due to only starting at cylinder 2.
Happy new year. Günther
Old Dec 30, 2006 | 11:45 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
-alex
I agree with 1fastC3, it sounds like they have ajusted for the offset of the exhaust port from side to side.
Neal
dmaaero's Avatar
dmaaero
i see now what your saying about the passenger head being closer to the firewall had me going for a little while though, i got the hooker mufflers i asked for the loudest most free flowing muffler they had and they sent a muffler with a 1 1/2 hole in it i dont care much at all for the idea of going from 4 inches to 1 1/2 inch exhaust opening are they obnixious loud with no muffler? also should i use the gaskets they sent or use fel pros?
Old Dec 30, 2006 | 01:55 PM
Burnt71's Avatar
Burnt71
Default Very Loud
Old Dec 30, 2006 | 02:09 PM
SteveG75's Avatar
SteveG75
Two things;
1. The engine in the C3 is offset to the passenger side. Take a look at the brackets that your engine mounts bolt to. The engine is about 2" (I am doing this from memory) closer to the passenger side frame rail.
2. The Hooker mufflers are crap. Get the STS baffles. www.spiralturbobaffles.com
You can always remove the center cap for more flow and noise.
Edit: I use the Mr. Gasket Ultraseal Gaskets. Metal cored with graphite on both sides. Seals well and easy to find at Autozone when I need one in a hurry.
Old Dec 30, 2006 | 03:17 PM
dmaaero's Avatar
dmaaero
thanks guys i'll send the hookers back and get the turbo mufflers i got it on stands (scary) and got the old exhaust off so far , they sent metal core graphite gaskets so i'll stick those on got my hands washed goin for the shinny stuff now
Old Dec 30, 2006 | 09:28 PM
Indynut's Avatar
Indynut
SteveG75 is 100% correct, cause I had to cut a hole in my engine hood this year and it could even be more than 2 inches over toward passenger side of the car. Man oh man I wanna buy those headers so bad for my BB 'Vette.
Indy
Old Dec 30, 2006 | 09:33 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
My hooker Max Flow mufflers have a 2 1/2 " hole through the middle. Fit right in the sidepipe and are 1/2 price of the turbo baffles.
Old Dec 30, 2006 | 11:34 PM
dmaaero's Avatar
dmaaero
i got the 21021hkr looks like i ended up with the glass pack muffler
Old Dec 30, 2006 | 11:40 PM
1fastC3's Avatar
1fastC3
ive got some of these http://www.sweet-thunder.com/chamber..._corvette.html they sound nice and are pretty good, just my $.02, good luck with what ever you do.
-alex
Old Dec 30, 2006 | 11:54 PM
dmaaero's Avatar
dmaaero
i put he pipes on with no mufflers an got to thinking i'll get a ticket goina be to loud so i took the pipes back off and put the mufflers in i'll probly eat these mufflers cause i ain't sitting around waiting on new mufflers to come i only had my car 3 weeks i wana ride i do know it's a real pain getting the sidepipes off the header and it hasent been run yet i can only imangine it'll be worse after it's been hot
To hooker sidepipe ?
