Need More Power!
If the advance is to spech you need to set it at 12 to 16 degrees BTDC. You'll need to reset the idle speed after doing this. What does the centrifugal advance curve look like. You should have 36 degrees in by no more than 2800 RPM.
BigBlockk
Later.....
I plan to "loosen up" the spring load on the upper plates so they will respond faster and adjust the rod to ensure the lower plates will open fully straight up.
With the pump I plan to move the rod connection to the lower hole to get a shot into the carb sooner.
Then after I see what it does I may look into a rebuild kit or give Lars a call.
cc
Then Lars recurved my dist and things got better, only a little.
I went with 3.55's. Then things got alot nicer.
3.70's are too high for the street, IMHO. I added a hidden MSD, still using points. A saw a minor improvement. A chambered exhaust added sound, but not much go. ..... Finally .... a local carb expert got a hold of my Q-jet. And $500 dollars later, the old girl runs like a CORVETTE SHOULD. My carb was pretty out of wack and now the car doesn't even run hot!
So if you want to learn from my experience:
- gears
- Good carb work ..... spend the $$ it makes a difference
- put on a nice exhaust and headers will wake it up.
After that it the standard stuff, intake, heads etc and the $$$ will really start to leave your pockets.
carbster
Thanks for the advice. My remanufactured carb has some funky numbers on it (29202DH 1759) where you'd expect to see 704xxxx.
Is there any way to be sure I have a Qjet that is up to the task before I put a bunch of money into it?
cc
