Rear spring: What would you do?
Old Jan 1, 2007 | 06:26 PM
MN80Vette's Avatar
MN80Vette
Default Rear spring: What would you do?
I posted some questions this morning and didn't get any replies. I can't believe C3 CF'ers don't have answers or opinions.
I'll try rephrasing the question:
If all you had to do was replace the rear spring mounting plate, would you:
  1. Jack the car up and disconnect the spring pad bolts before removing the mounting plate?
  2. Just unbolt the spring mounting plate and count on the weight of the car to stop lateral movement of the spring on the diff carrier?
  3. Jack the car up to reduce the load on the spring before unbolting the mounting plate?
Old Jan 1, 2007 | 06:29 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
#2 will work just fine!
Old Jan 1, 2007 | 09:13 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I don't think the spring will move under any of your senarios.
HOWEVER, springs can bite, so you might consider making some headless bolts to allow you exchange them one at a time without ANY chance of the spring slipping.
Old Jan 1, 2007 | 09:20 PM
84rzv500r's Avatar
84rzv500r
It would be a safer way to do it... not mandatory but safer.
Old Jan 1, 2007 | 09:29 PM
w1ctc's Avatar
w1ctc
Why take any short cuts. It won't take much longer to do it right and remove the spring end bolts. It will also be a good time to check the spring, bolts and the rubber parts.
Old Jan 1, 2007 | 09:31 PM
SIXFOOTER's Avatar
SIXFOOTER
Like someone said, springs bite....hard. Do it right, kack it up, remove the spring, clean the parts and put it back together
Old Jan 1, 2007 | 09:40 PM
ShinodaVette's Avatar
ShinodaVette
It's pretty easy to just remove the whole spring and be safe. It's not worth the chance of something going wrong.
Old Jan 1, 2007 | 09:50 PM
MN80Vette's Avatar
MN80Vette
That's a good idea! That spring has about 3/4 ton stored up. I certainly wouldn't want to be standing under it if it decided to flip out. I can remove a bolt and slip a smaller but longer bolt or two in from the top.
I'll check the bolt for side force on the safety bolt and take some weight off the spring or just remove it altogether if necessary.
The spring was re-installed in August with new bolts, cushions, washers, etc. when I had the trailing arms rebuilt, new half shafts, new shocks, etc. I've only driven the car a couple hundred miles since the rebuild, so everything is pretty clean.
Thanks for the input!
Old Jan 1, 2007 | 09:58 PM
MN80Vette's Avatar
MN80Vette
BTW, here's a current picture of the rebuilt driver's side rear suspension:
Old Jan 1, 2007 | 10:02 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I'm a little confused - why would you try to slip a smaller bolt in ????
Remove the 4 bolts (I think they're 7/16") and replace them with 4 pieces of all-thread ....one at a time
Reverse the process when re-assembling .....
Old Jan 1, 2007 | 10:15 PM
doug_dayson's Avatar
doug_dayson
I've done #2 with a VP&B Fiberglass Spring, no problems...
Old Jan 1, 2007 | 11:53 PM
MN80Vette's Avatar
MN80Vette
Good idea. I was thinking of using a smaller bolt because I wouldn't have to match threads. All-thread would work if I had the correct size all-thread rod. '80-'82 mounts have 3 fine-thread bolts. My neighborhood hardware store only had coarse thread. I'll check a bigger hardware store.
Thanks!
Old Jan 2, 2007 | 01:23 PM
sly vette's Avatar
sly vette
You guys got me stumped...What is all thread????
Old Jan 2, 2007 | 01:52 PM
rip74's Avatar
rip74
"All Thread" refers to a piece of threaded rod that can be cut to any length, thus the entire rod is threaded.
Old Jan 2, 2007 | 02:07 PM
69 Vette's Avatar
69 Vette
Old Jan 2, 2007 | 02:15 PM
jgrigg's Avatar
jgrigg
I just started my rear suspension last week. Only took me about 2 hours to remove the rear spring all together including putting the car up on stands.
I'm just a novice, but in my opinion, the extra time to do the job right is worth it.
Jeff
Old Jan 2, 2007 | 03:08 PM
68/70Vette's Avatar
68/70Vette
I notice that your current spring is a fiberglass spring. My experience with my car is that the fiberglass spring is easy to remove at the trailing arm attaching bolt. The fiberglass spring doesn't seem to have that much "spring" in it when it comes time to remove the end attachmnet. The steel springs still have a lot of spring force left when you undo them at the ends, and so are a lot more dangerous.
To Rear spring: What would you do?
