Front spring compression
Old Jan 2, 2007 | 11:38 AM
b-line's Avatar
b-line
Default Front spring compression
I have run into a bit of a problem with my front-end overhaul job. I have the control arms installed and am ready to install the spring, then attach the spindle and shock. I also have the engine out of the car and I can't get the spring to compress enough to attach due to a lack of weight on the front end. I have a spring compressor but, how do you compress the spring while it is in the conrol arms and still get the s-compressor out or is there another method?
Old Jan 2, 2007 | 11:44 AM
72LS1Vette's Avatar
72LS1Vette
You can drop the compressor bolt down through the upper shock mount hole and compress the spring. I found that you might need to use a pry bar to get the spring seated in the upper pocket since the pocket is at an angle.
If you are working in a garage you could also wedge a 2x6 between the frame and a ceiling joist to hold the front end down while you jack the lower control arm.
Rick B.
Old Jan 2, 2007 | 11:55 AM
jnb5101's Avatar
jnb5101
be sure to use a safety chain.
Old Jan 2, 2007 | 12:14 PM
68 NJConv 454's Avatar
68 NJConv 454
I remember how much of a PIA it was just to get the spring compressor into the coil spring to get the darn things off the car.
Just make sure your grabbing as many rings as possible then compress as much as you can. Don't losen the spring compressor until the spindle is torqued down to the a-arms.
Be very very careful as even worn springs can pack a punch and hurt you badly.
I didn't put my springs back on, i installed the front monospring.
Wish I could offer more guidance, good luck.
Old Jan 2, 2007 | 01:12 PM
ShinodaVette's Avatar
ShinodaVette
I bought the Eastwood internal spring compressor to do mine with the body off. I put it up through the bottom of the lower control arm and grab coils up as high as I can. The bottom part of the spring compressor won't go through the hole in the lower control arm but it locks in nicely in the control arm hole due to the wedge shape of the lower part of the compressor. I'll try to shoot a pic of it tonight as I am in the process of putting the springs back in.
The other thing I am doing is putting them in backwards compared to what most people seem to do. The factory repair manual states to unbolt the control arm from the cross member to replace the springs rather than unbolt the control arm from the steering knuckle. I feel this puts the spring at a better angle to go in than going the other way. So, right now I have the knuckle connected to the control arm (i.e. ball joint) and the other end of the control arm loosely bolted to the cross member. I will then unbolt it from the cross member and put the spring in and bolt it back up.
Hope that helps some.
Old Jan 2, 2007 | 01:20 PM
Michelp's Avatar
Michelp
Heres how I did it.
1 Pass a threaded rod big enough thru the shock hole on top of the shock tower in place of the shock.
2 from underneat put a plate about 6by 6 in and a bolt.
3 on top put a washer and a bolt and compress the spring until its in his final position and install the upper ball joint.
Decompress the spring by removing the bolts ond the threaded bar
Its safe because the spring cant go anywhere.
Old Jan 2, 2007 | 03:01 PM
BB72's Avatar
BB72
Default Band the springs
I had to band the springs at a shop, they charged $50 CND, the spring compressor didn't work so I had to do this. I also have no weight up front so it was a PIA, spring compressor didn't work with BB springs . Much safer too.
Old Jan 2, 2007 | 03:08 PM
b-line's Avatar
b-line
Default Front Spring Compression
Just wanted to thank those who reponded to my question. I like the idea of putting the spring compressor throught the bottom shock tower hole. Also, the 6" plate and bolt looks like it's safe and will work. This is my first attempt at a project of this size and I have to tell you this forum is a real asset. Every time I get stuck I come here and get what I need. Thanks again to all.
71 corvette Brandy-Hatch Green T-tops Turbo 400 auto soon to have a 383 stroker. Gotta get all this other stuff done while I have the engine out.
Next is the steering components.
To Front spring compression
