Vacuum to advance
Old Jan 2, 2007 | 09:57 AM
A2vette's Avatar
A2vette
Default Vacuum to advance
Will the vacuum advance work correctly if I use the vacuum from the intake manifold instead of the carb? If so, what are the pros and cons?
Paul
Ann Arbor, MI
Old Jan 2, 2007 | 10:21 AM
Durango_Boy's Avatar
Durango_Boy
Paul
Ann Arbor, MI
It should work fine no matter where you keep it, but the vacuum off the carb changes directly with the throttle, so it's a more accurate source. I could be wrong...that's just my understanding of it.
Old Jan 2, 2007 | 10:57 AM
lars's Avatar
lars
Manifold vacuum is the same regardless of whether you pull it off the carb or the manifold. The carb does have a single ported vacuum source that you can use if emissions are a concern, but the manifold vacuum sources will generally provide better throttle response, drivability, and lower engine temps.
Old Jan 2, 2007 | 10:58 AM
RPOL68's Avatar
RPOL68
No. They are totally different in nature. For the most part, manifold vacuum is highest at no load (throttle closed) and drops under load (throttle open). Ported vacuum comes from the throttle venturi and is at zero or minimal at idle and increases with RPM. Some carburators have sources for both but they do different things and are not interchangeable.
Old Jan 2, 2007 | 11:03 AM
lars's Avatar
lars
Not correct. Ported vacuum has nothing to do with venturi vacuum. Ported vacuum is simply located in a position relative to the throttle blade that the vacuum source is shut off at idle. At any throttle setting above idle, ported vacuum is the same as manifold vacuum. Ported vacuum is used to eliminate vacuum advance at idle in order to reduce hydrocarbon emissions. At all throttle settings above idle, ported vacuum is the same as manifold vacuum.
For a complete description on manifold vacuum, ported vacuum, and venturi vacuum, simply drop me an e-mail request for my "Vacuum Explained" paper:
V8FastCars@msn.com
Lars
Old Jan 2, 2007 | 11:04 AM
A2vette's Avatar
A2vette
So, I should not use the vacuum from the manifold.
Old Jan 2, 2007 | 11:05 AM
Durango_Boy
I think Lars was saying the manifold is the best place to get the vacuum from if you don't want to use the carb.
Old Jan 2, 2007 | 11:10 AM
lars's Avatar
lars
Manifold vacuum at the manifold is the same as manifold vacuum at the carb. The only vacuum source that is any different is the single ported vacuum port found on most carbs. You can use the ported vacuum if you do not want vacuum advance at idle. Use any other vacuum source, either at the carb or on the manifold, if you want vacuum advance at idle. Most engines will respond better to vacuum at idle, but you need to see what your engine "wants" and tune accordingly, as long as emissions are not a concern.
Old Jan 2, 2007 | 11:21 AM
A2vette's Avatar
A2vette
Default Needed info
I sent you a request for your expertise on vac and timing to your email address.
Thanks,
Paul
Old Jan 2, 2007 | 11:41 AM
lars's Avatar
lars
Hey Paul -
Since I'm at the office right now, send me your request to the following e-mail, and I'll get you the info right away:
lars.grimsrud@lmco.com
Lars
Old Jan 2, 2007 | 12:39 PM
lars's Avatar
lars
Just sent you 3 papers related to vacuum and timing. Tag me back if you have any questions on any of the systems and concepts.
Lars
Old Jan 2, 2007 | 12:50 PM
BigBlockk's Avatar
BigBlockk
One will have ported vacuum long before there is enough air flow through the venturi to supply a usable signal. Ported vacuum is taken off the throttle bores just above the throttle butterflies. As the throttles open the vacuum port is exposed to manifold vacuum.
BigBlockk
Later.....
Old Jan 2, 2007 | 01:00 PM
A2vette's Avatar
A2vette
Thanks for the help.
Paul
Old Jan 2, 2007 | 03:26 PM
79-L-82's Avatar
79-L-82
Not to hijack the thread, but. . .
I have the timing set where I think i need it, but; with the vacuum advance attached at either the ported source or the manifold, I get a ping once the engine is warmed up at light throttle for a second.
For example, if I am cruising, no ping, but; accelerate slightly and pings for a sec. If I floor it, no ping. When I disconnect the vacuum advance, it runs great. right now it's not hooked up.
Any thoughts??
Old Jan 2, 2007 | 03:47 PM
lars's Avatar
lars
You might have a vacuum advance control unit (aka "vacuum can") that is either too light (pulls in with very little effort), or one that has too long of a curve (pulls in too many degrees of vacuum advance). You need to custom tailor the vacuum advance to your requirements. Which vacuum advance control unit are you using? What is your total timing? You need to be at 36 degrees total and then use a 16-degree vacuum advance.
I have a paper that covers all of the control units with all the specifications and part numbers. E-mail me for a copy:
Lars
Old Jan 2, 2007 | 03:59 PM
79-L-82's Avatar
79-L-82
Total is set to 36* per your advice last year.
Thanks, by the way. . .
I'll send you an email for the specs on the vacuum advance.
Old Jan 2, 2007 | 04:05 PM
Clint's C3's Avatar
Clint's C3
FWIW, MSD told me to use the vacuum source on the carb. Another question, does total advance include vacuum advance??? I have 36 degress with intial timing of 10 degrees plus mechanical, but when I hook up the vacuum it increases it to ~45. I don't have knock or running problems but is this right?
To Vacuum to advance
Old Jan 2, 2007 | 04:13 PM
lars's Avatar
lars
All carbs have 2 vacuum sources: manifold vacuum and ported vacuum. You need to hook up to the correct source and know what you're hooking up to. The manifold vacuum ports on the carb are the same as any manifold vacuum source on the manifold. Ported vacuum is only available on the carb, providing you know which vacuum nipple it is...
Total advance does not include vacuum advance. It is total mechanical advance only. So with 36 total, you should get another 16-or-so with vacuum hooked up, to produce a maximum total combined advance of 52-54 degrees. If you have 10 degrees initial and pull in 16 degrees of vacuum at idle, you'll get around 26-or-so degrees of timing at idle.
Old Jan 2, 2007 | 04:21 PM
Clint's C3's Avatar
Clint's C3
Thanks for the explanation and papers. 54-56 degrees sounds like a lot but seems to work.
Old Jan 2, 2007 | 06:05 PM
lars's Avatar
lars
56 is a little much - you don't want to go beyond 54 total combined with vacuum. I target 52-54 to stay safe.
Lars
