Rear axle Numbers?
Old Jan 3, 2007 | 11:14 AM
1971454vette's Avatar
1971454vette
Default Rear axle Numbers?
I have a 1971 vert and the rear axle has the stamping of AXW 75E2. My NCRS spec guild doesnt list that number with the W in it for 1971. The book does list the W in1965-1969 years. I'm confused, can anyone help decifer this number? Do I have an older axle? That would be a bummer because everything else in the car is numbers matching! Don
Old Jan 3, 2007 | 12:15 PM
Patrick73's Avatar
Patrick73
I am not a 71 to 72 expert, but I think you have the OEM differential.
71-72's have a two letter differential production code (AX); this is followed by a third letter denoting the assembly plant. ( The W is for Warren, Michigan)
Then comes one, two or three letters denoting the day of the year the unit was built ( 75th day). Then a single letter indicating the source of the unit (E for Eaton); The final number represents the shift that buillt the unit (2= second shift).
AX for 1971 is 3.36 ratio; positraction.
Old Jan 3, 2007 | 12:39 PM
wfo76's Avatar
wfo76
AXW 75E2
AX.....3.36
W......Warren Gear Plant
75......Julian Date (75th day of 1971 or March 16, 1971)
E........Eaton positraction unit
2........assembly plant second shift
Old Jan 3, 2007 | 08:31 PM
1971454vette
WHOO-HOO!!!! the 75 and the E2 explanation are new to me. But Now.. I... Know! thanks guys. Don
To Rear axle Numbers?
