Nitrous install - part 3
Old Jan 3, 2007 | 10:01 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Nitrous install - part 3
Did the wiring today. Also hooked up the retard system..
Still need to get some brackets to route the wires etc. but I'm almost done!
Old Jan 4, 2007 | 12:40 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Make sure to test EVERYTHING, selinoids open, retard works, WOT switch etc, etc. Getting closer
Old Jan 4, 2007 | 01:52 AM
BigBlockk's Avatar
BigBlockk
As weight conscience as you are I would have thought you would have installed an '80's style aluminum master cylinder. Ever looked into that?
BigBlockk
Later.....
Old Jan 4, 2007 | 05:53 AM
GrandSportC3
absolutely!! Will test alll components!!
Old Jan 4, 2007 | 05:58 AM
GrandSportC3
BigBlockk
Later.....
Hmmm... didn't know that there is one that would fit? I have no power brakes and I thought that all later vehicles had power brakes..
Which one would fit?
Old Jan 4, 2007 | 06:51 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Lookin good Ollie
Old Jan 4, 2007 | 09:19 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Don't forget pills. Also, once you hook everything up go ahead and spray the fuel/nitrous. No ignition. Pull the lines at the filters/pills and clean out any tape or debris.
Old Jan 4, 2007 | 09:33 AM
GrandSportC3
pills??
Old Jan 4, 2007 | 12:56 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Otherwise known as jets...
Description....or perscription
Nitrous Jet (Pill): Jets, or pills as they are sometimes called, are small machined pieces resembling little arrows that offer precise control of the nitrous and fuel flow to the engine.
Old Jan 4, 2007 | 01:12 PM
mrvette's Avatar
mrvette
http://www.piratejack.net/troubleshooting/specs.htm
look around there for an aluminum m/cyl....the one I"m using with hydroboost....works fine....real fine...
Old Jan 4, 2007 | 01:18 PM
Twin_Turbo's Avatar
Twin_Turbo
Why is no one grabbing from the C4 parts bin? I'm going to upgrade to a larger one (need bigger bore for huge calipers) otherwise it looks pretty damn good. The only thing you need to do is expand the bolt holes on the flange to slots as the bolt spacing is a little different. Since the MC is aluminium it's easily done even with a hand file
Old Jan 4, 2007 | 02:15 PM
GrandSportC3
Discription....or perscription
Aahhh... jets!
For me, pills are for MSD components
Old Jan 4, 2007 | 02:32 PM
GrandSportC3
Is any of those a bolt on with no modifications?
Old Jan 4, 2007 | 03:03 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Originally Posted by GrandSportC3
Aahhh... jets!
That too.
Old Jan 4, 2007 | 06:30 PM
GrandSportC3
pills... hmmm..
To Nitrous install - part 3
