Water circulation
Old Jan 5, 2007 | 09:12 AM
Vesa's Avatar
Vesa
Default Water circulation
If you look that small hose connecting water pump and intake manifold:
http://www.crateenginedepot.com/stor...78-P11C54.aspx
An here it is not intended to be there:
http://www.worldcastings.com/prods_pages/108052.htm
Does somebody know the logic here? Should I just plug the water pump outlet and be happy and no problems will arise?
Old Jan 5, 2007 | 11:10 AM
Durango_Boy's Avatar
Durango_Boy
Unless you know for sure...I would run a bypass of some sort. Don't want to mess with the cooling system if you don't understand why something is there.
Old Jan 5, 2007 | 11:59 AM
lars's Avatar
lars
1986 and newer big blocks used a bypass hose. The one engine in your referenced picture is a late-model big block with the hose. The other engine is patterned after the early big block design and does not use the hose. When using an aftermarket intake manifold with the late-model blocks/water pumps, you have to use Edelbrock part number #8028 waterneck adapter to retain the hose feature.
Old Jan 5, 2007 | 01:16 PM
Vesa's Avatar
Vesa
Thanks Lars!
So if I buy that engine:
I do not need to use a hose between water pump and the manifold - I just block the outlet from the water pump!?
How come in my old 1968 396 with a GM iron short water pump and GM L-88 intake manifold there is also a hose connecting manifold and the pump That does not fit what you said about early big block design? Or did I misunderstand that part?
Old Jan 6, 2007 | 01:16 AM
Durango_Boy
I know that if you plug the bypass hose outlets on Dodge motors, they will overheat. I wonder how important they are on engines that already had them.
Old Jan 6, 2007 | 01:50 AM
Vesa's Avatar
Vesa
Does anyone have clue n what is the actual purpose of that hose? And how the logic has been changed in engines which do not use it?
Old Jan 6, 2007 | 03:16 AM
TimAT's Avatar
TimAT
When I was just a bit younger my elders had a '65 Impala 396/325 that had the bypass hose, and a very long stream of others I've seen have also had it, including my '69. It allows water to circulate thru the water pump and block before the t'stat opens to the radiator..
Old Jan 6, 2007 | 04:14 AM
Vesa's Avatar
Vesa
Now I see. The water comes back from the engine into water pump via that small hose - so it bypasses the radiator before termostat opens!?
So if you have a small drilled hole in your termostat or have a hi-flow type termostat that also has a small bend (allowing small amount of water to go through the termostat before the engine has warmed up) you do not basically need that hose in any application.
Maybe it only prevents hot spots to happen before termostat opens in applications with normal totally closing termostats. And also via circulation the warming water a bit, ensures that the termostat really gets average warmth of water and opens as soon as needed - if no circulation at all the water staying still close to termostat does not warm up that fast at all and at the back of the engine the not moving water is really hot already...
Old Jan 6, 2007 | 09:50 AM
gerry72's Avatar
gerry72
You got that part right, but the rest of it isn't quite right.
The purpose of the bypass is twofold: 1)Allows a faster and more even warmup when the t-stat is closed by circulating the water throughout the block. So the path is into the water manifold, into the pump, and back into the block; 2)gives you a narrow buffer in the event of t-stat failure. Instead of the engine going thermo-nuclear immediately, the engine temp will rise gradually and give you an opportunity to get off the road. This is because the water temp is rising evenly instead of immediately boiling in the heads.
Drilling holes in the t-stat, as you can see, does not do the same thing as a bypass. By doing it that way, you will ensure a slower and less even warmup by introducing cold radiator water into the engine. On warm up, you don't want the water to enter the radiator. You want the engine to come up to temperature, then regulate that temp with the radiator. Besides, it would be very difficult to get the same flow volume through a drilled t-stat that you get through the bypass.
Old Jan 6, 2007 | 01:46 PM
Durango_Boy
Okay...all that being said, will an engine, say a small block, run okay with no bypass?
I have a 400, with '89 heads, reverse flow water pump, and an LT1 manifold.
The water pump does not have a bypass or heater hos nipple. Just the ports that bolt to the block.
How will this affect cooling, and do I need to plumb anything special?
Old Jan 6, 2007 | 09:48 PM
noonie's Avatar
noonie
Here is a quote from Stewart Water Pumps you may be interested in.
...and Stewart Stage 2, 3, and 4 water pumps simply will NOT operate with a regular thermostat because these pumps have no internal bypasses.
Stewart further modifies its thermostat by machining three 3/16" bypass holes directly in the poppet valve, which allows some coolant to bypass the thermostat even when closed. This modification does result in the engine taking slightly longer to reach operating temperature in cold weather, but it allows the thermostat to function properly when using a high flow water pump at high engine RPM...
Take from:
http://www.stewartcomponents.com/tec...ech_Tips_3.htm
The rest of their website has good info too and some schematics of other flow maps.
As far as the Robert Shaw tstats and bypasses are concerned, they are the only ones I know of, that fail in the open position so as to not create this:
They are only $9.00 locally so it's well worth it for the added insurance.
It may be in your best interest to give Stewart's a call for your specific application.
Hope this helps
Old Jan 6, 2007 | 11:47 PM
TimAT's Avatar
TimAT
Take a look at the mounting bosses on the SB water pump. Note there are 4 holes on one side and 3 on the other, (counting the water passages. That extra hole is the bypass on a small block.
Old Jan 6, 2007 | 11:56 PM
Big2Bird's Avatar
Big2Bird
Yep
Old Jan 7, 2007 | 10:45 AM
Durango_Boy
Does that apply to the later year reverse flow water pumps too?
Old Jan 7, 2007 | 10:47 AM
David Ey's Avatar
David Ey
exactly what is a reverse flow pump and why use one
Old Jan 7, 2007 | 10:53 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Have a look:
http://www.theherd.com/articles/lt1_cool.html
Old Jan 7, 2007 | 11:36 AM
noonie's Avatar
noonie
Are you using a reverse flow pump because of a serpentine belt conversion?
Or are you converting to reverse flow cooling?
There is a difference.
To Water circulation
Durango_Boy
Originally Posted by Jud Chapin
Great paper Jud. Thanks.
My engine is an LT1 manifold on a Gen1 block. Because I'm using the '92 Camaro serp, I had to use a modern reverse rotation pump.
I know the flow will work just fine in the block, and I will get all the reverse flow benefits...but I'm confused about the bypass. I will have to use the remote thermostat housing, with the two heater hoses coming from the back of the intake manifold.
I will drill a few holes in the T-stat if that's the fix.
Old Jan 7, 2007 | 01:50 PM
Vesa's Avatar
Vesa
A few hole...1 would be enough...
Old Jan 7, 2007 | 03:06 PM
Durango_Boy
Okay...thanks.
