HELP - No Electrical Power and Won't Start
Old Jan 6, 2007 | 04:25 PM
VolVette's Avatar
VolVette
Default HELP - No Electrical Power and Won't Start
My '75 (a/t) quit while driving and will not start. There is no electrical power to anything and when I turn the key, nothing happens. This shut down was a complete surprise with no symptoms.
Battery has 12.3 Volts and connections are tight. I changed the starter about 2 months ago and that may have something to do with it.
The problem is IT IS ABOUT TO RAIN, there is no power to the windows and it broke down away from my house.
Could someone please recommend where I can troubleshoot to find where my problem may be?
Thank you!
Old Jan 6, 2007 | 04:34 PM
Big2Bird's Avatar
Big2Bird
Thank you!
Check the fusable links at the starter.
Old Jan 6, 2007 | 04:38 PM
VolVette's Avatar
VolVette
Is there any way to check that without having a jack and lifting the car?
Old Jan 6, 2007 | 04:45 PM
VolVette's Avatar
VolVette
Could a fusible link or loose starter wire cause failure when I'm just driving along?
Big2Bird's Avatar
Big2Bird
On an 81, yours should be similar, one link feeds the light switch, the other goes to the fuses and the large alt. post. Check for voltage at these locations.
Old Jan 6, 2007 | 04:46 PM
Big2Bird's Avatar
Big2Bird
Yep. Although I need more info to tell why.
Old Jan 6, 2007 | 04:50 PM
VolVette's Avatar
VolVette
I'm going to go back down to the car in my other car and I will come back with what I see.
Thank you.
Old Jan 6, 2007 | 05:34 PM
VolVette's Avatar
VolVette
I really don't know what I did, but I wiggled some wires and moved a few wires around the starter and she fired up and is safely back in my garage.
Thank you for your help. I will now check all the wires at the starter and try to figure out what caused the problem.
Old Jan 6, 2007 | 05:39 PM
PRNDL's Avatar
PRNDL
It went dead while driving? Obviously, you don't need the starter to keep the motor running. Is there a ground near the starter that you need to keep the engine running?
Old Jan 6, 2007 | 08:10 PM
VolVette's Avatar
VolVette
That was my same thought. There must be. I really don't understand why it quit or why it started back up. But there is good potential for wires crossing around the starter.
To HELP - No Electrical Power and Won't Start
