82 intake porting
Old Jan 7, 2007 | 12:08 PM
hoss82's Avatar
hoss82
Default 82 intake porting
I was thinking about opening up the intake castings on my 82. Is it worth grinding down the block off plates on the intake manafold, or should I just leave it alone. Just thought it might be a cheep mod. I wouldn't have to buy anything that is. (except for a few gaskets.)
Thanks.
Old Jan 7, 2007 | 12:35 PM
Twin_Turbo's Avatar
Twin_Turbo
block off plates?
Old Jan 7, 2007 | 12:37 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by Twin_Turbo
block off plates?
Old Jan 7, 2007 | 12:50 PM
hoss82's Avatar
hoss82
The original casting of the manifold covered half of the intake ports where the manifold meets the head in an effort to reduce performance and increase fuel economy. I haven't seen them myself other than technical article pictures, but if I have them should I grind them out? Maybe they don't exist and I'm a wacko. anybody have any experience wih this?
Old Jan 7, 2007 | 12:55 PM
wfo76's Avatar
wfo76
I would just go with one of these
http://www.x-ram.com/crossfireinfo.html
Old Jan 7, 2007 | 12:57 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, but it's cast in and there's a dimple in the runner so you can't grind out a whole lot, you can match the first half inch or so but after that you can't, the runner is 3/4th the size of a normal runner over the entire length.
Old Jan 7, 2007 | 04:54 PM
hoss82's Avatar
hoss82
Thanks Twin Turbo. Looks like a lot of hassle for not much gain. I think they'll stay.
Cheers.
Old Jan 7, 2007 | 04:56 PM
Twin_Turbo's Avatar
Twin_Turbo
smoothing theend to match the head does help a little, just do it.
Old Jan 7, 2007 | 11:19 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Take a look at the crossfire injection vault website. There are a BUNCH of guys there that do the prot matching. One guy picked up almost a half second in the qauarter mile, and said his car pulls a lot stronger on the high RPM range now.
I definitely think it is worth it.
Some go as far as to grind away the EGR too.
There are some great pictures there.
I don't know if I should be plugging another forum, but I learned alot from there and am glad I found it. CF is my home, though.
To 82 intake porting
