Dash pad removal?
Just place your palm on the under side in the middle and push down on the
side your having trouble with.
You have to take the A-pillar pads off first!
There are two screws at the top of each, one going through the sun-visor bracket and one that screws upwards into the frame. Then ease the pads out, pulling the tops out then the whole pad up from behind the dash-pad.
Then remove the passenger dash-front to access a bracket that attaches the underside of the dash-top to the bulkhead.
Remove all other screws between the dash front and top (centre consol and drivers side).
The top dash pad should now be ready to come out. Pull it back (towards you) to disengage two clips that hook onto bulkhead brackets.
Now the tricky bit, use some force to push the dash to one side, and at the same time pull the other end out from behind the A-pillar. I usually push toward the drivers side and remove the passenger corner.
The dash should now be sittling on your lap
, and you think your troubles are over but be careful re-installing it. I think it's harder than removal.
Mainly watch out for the two clips snagging on things (especially the defroster vent).
Good luck, and just remember to be firm but gentle (childish chuckle)
SEMPER FI-- 1970 Dave
I was able to reinstall it using the same method with no problems. I probably spent a good five to ten minutes warming it up
