700R4 driveshaft length?
Old Jan 8, 2007 | 06:52 AM
jerome1979's Avatar
jerome1979
Default 700R4 driveshaft length?
I need legth, because i will convert my corvette with Th350 to a T56 from a GM car
700r4 (4l60) have same legth than a T56 (info from several website)
Old Jan 8, 2007 | 08:31 AM
mrvette's Avatar
mrvette
cut 2.5 inches off you stock shaft.....
BTW, I have one for sale.....the correct length...
Old Jan 8, 2007 | 09:28 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
don't cut anything until the unit is installed and you measure it.....as gene said i cut about 2.5" off of mine but i wouldn't cut anything unitl i had a chance to measure it and remember the yoke goes to the drivline shop also because they balance them together.
Old Jan 8, 2007 | 12:00 PM
jerome1979's Avatar
jerome1979
that something very "mad" i don't understand why!!!
Mr chevrolet when he make a corvette he know dimenssion! and this dimenssion are not different for each corvette!
so why we couldn't cut before install? when we kow the dimenssion of transmission???
i realy don't understand!
and about driveshaft:
cut a driveshaft in France isn't easy few guy make this!
Ps: i'm on the bad side of the ocean
Old Jan 8, 2007 | 12:11 PM
markdtn's Avatar
markdtn
All are made similar but there are variances. Especially since it costs so much, I would wait and measure. Also you CANNOT use an 82 driveshaft (without cutting it) in an iron rear differential car (63-79). The aluminum diff cars (80-82) it will bolt right in.
Old Jan 8, 2007 | 12:32 PM
bobs77vet's Avatar
bobs77vet
well you are mixing and matching components so there can be differences. if you have ever installed a drive shaft that is too long you will understand why we are saying to measure first . this is one area that really has to be right the first time. any truck repair shop should be able to do this for you.
Old Jan 8, 2007 | 08:41 PM
bozzman3's Avatar
bozzman3
Is a 1982s driveshaft the right length for a 1980 getting a 7004r?
Old Jan 8, 2007 | 10:10 PM
mrvette's Avatar
mrvette
The way I understand, primarily from off this forum, is the differances in shaft length was changed for the '80 year production.....
so the '70's cars take one shaft length, and the 80s another entirely....
after that, you get the guy wanting a 700 tranny, that means a custom shafting....
Old Jan 9, 2007 | 09:11 AM
markdtn's Avatar
markdtn
Yes. It will work 80-82 with 700R4.
To 700R4 driveshaft length?
