Ceramic Headers vs Wrapped?
Old Jan 11, 2007 | 02:06 AM
Graemeinvette's Avatar
Graemeinvette
Originally Posted by bruced267
So which is it? Which one reduces under hood temps? One says wrap, and another says cermic. I always thought it would help reduce? It is a thermal coating
The answer is they both do.
I've been running Dynomax Ceramic coated headers for over a year now, they still look really good and they reduced the heat levels dramatically.
Old Jan 11, 2007 | 08:45 AM
shafrs3's Avatar
shafrs3
Ask yourself this question, which do you think would give you better protection from a nasty burn grabbing a piece of red hot metal, some tin foil coated with a ceramic coating or a pot holder made from header wrap?
Here's another analogy, imagine two mirrors, one the kind normally found in a bathroom and one that's reflective surface is made from a ceramic header coating. Which one do you think would tan (or sunburn) you faster reflecting the suns ray's on to your skin? Do you think you could get a tan with a mirror made from header wrap?
Heat control is using a material that resists the flow of heat, no way is a coating a thousandths of an inch thick going to slow the flow of heat like a heat resistive cloth that's a about a hundred times thicker. My money is on the wrap in both scenarios for shielding conductive and infrared heat.
Old Jan 11, 2007 | 07:01 PM
blctalon's Avatar
blctalon
I would not wrap any set of headers ever again. Someone posted a similar thread probably a year ago and I suggested wrapping the headers to cut down on underhood temperatures and such, which wrapping helps.
Wrapping the headers also retains much heat with will cause crystalization or something of the tubes and make them break down. I had a set of hooker regular non-coated headers on my truck for a couple of years and they started to get a little surface rust so I took them off and cleaned them up then wrapped them. They have lasted about 2 years to be exact. Funny they are leaking now, because when I ordered my Stan's Tri-y ceramic coated headers I told them what I did to my truck headers and they couldn't believe they had lasted that long. One week later the damn things started leaking in the tubes.
I don't know about wrapping the exhaust pipes, as they may be more durable, but I'll never wrap another set of headers again.
Old Jan 11, 2007 | 10:55 PM
Red 69's Avatar
Red 69
Originally Posted by Red 69
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
It sounds like the header wrap should be outlawed, or maybe a case action lawsuit filed. Seriously, I don't know what to think. My wrap can be a test on how long the system will last. Maybe I cheated without knowing, as everything was painted with VHT silver before the wrap went on. If everything gets as hot as some claim, I figuer the 1200* VHT paint will be burned off and offer no rust protection. Since everything from the headers back was relatively new, it will be interesting to see how long the pipes last. The headers were not in as good condition, but very good anyway. The car is not a DD and will probably not see any rain. If I detect any signs of premature rust I will post an update.
Old Jan 11, 2007 | 11:07 PM
blctalon's Avatar
blctalon
You did a nice job on your wrap. Yes, I could imagine you did torture yourself if you did it all while installed on the car. :X It will definatley be interesting to know how long this setup lasts. I'm sure you'll have to replace the header gaskets to head and header to to exhaust pipes a couple of times before it's time to do something new.
Old Jan 12, 2007 | 07:16 PM
shafrs3's Avatar
shafrs3
I'd rather replace the headers every few years than the wiring harness.
Old Jan 13, 2007 | 02:22 AM
panic's Avatar
panic
i had my headers on another V8 engine (the tvr, that has the headers INSIDE the hood upside down!!) wrapped , heat dropped dramatically underhood and i didnt find any extra rust, the only con can be that as the wrap retains a lot of the heat coming from the engine, at a certain point the header itself could melt if you hammer on engine for long an at top engine speeds...if done properly the header wrap looks the business anyway and will never un-wrap or move whatsoever...
Old Jan 13, 2007 | 02:25 AM
panic's Avatar
panic
red, you dont need to wrap the whole exhaust sistem, the only place where it would work or be usefull is underhood and only on headers
Old Jan 13, 2007 | 08:26 AM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by Billysvette
If you garage the car and never drive in the rain,why would your headers rust out quick with them wrapped?
It isn't the moisture that does the headers in. They don't rust out faster. It is the retained heat. The metal gets so hot that is actually changes the structure, the metal literally rots from the constant overheating. Warranties are void because of this. It you remove the wrap down the road you will see the metal has a funny very large grain size, you can see this on the outside of the pipe, the metal is no longer smooth but looks like a coarse sand.
I wrap mine because of the greatly reduced under hood temperatures but am prepared to replace every so often.
If you wrap soak the wrap in water first, it makes it far more pliable, easy to work with.
Old Jan 13, 2007 | 08:59 AM
Red 69's Avatar
Red 69
Thanks for everyone's suggestions/tips on header wrap. The wrap started out to only protect my new composite spring from exhaust heat in that area. It was a solution suggested by Gary at VB&P that I preferred over a shield. After experiencing vapor lock in bumper-to-bumper traffic, I decided to wrap the headers as a possible solution, and going all the way back wasn't that much more. The interior temp dropped noticably, but I am not sure about it being a vapor lock solution. This weekend I will be in staging lanes at the strip, so I know soon enough. I also insulated my fuel line and trans fluid lines and added a trans cooler. With the collective additions something better be cooler, or I will get hot.
Old Jan 13, 2007 | 09:13 AM
panic's Avatar
panic
if you dont soak in water before fixing it, sooner or later you'll loose a piece here and another piece there.. and it won't do its job properly anyway.
Old Jan 13, 2007 | 09:32 AM
ESU's Avatar
ESU
Soooo, what about getting ceramic headers and wrapping them? Overkill?
ESU
Old Jan 13, 2007 | 10:26 AM
  #33
Crunch-o-Matic's Avatar
Crunch-o-Matic
ESU/Bruced -- I have Jetthot ceramic coated headers on a zz4 in my 73 vert. Originally I had plain headers and the heat was terrible. The ceramic coated headers are the best bag for the buck next to the TKO swap I did. Ceramic significantly dropped the heat temps not to mention they cool down very quick. As for longevity, I dont drive the car daily but, I think the ceramic route is better.
I think the biggest problem with headers (on this forum) is that people dont spend the money on good exhaust components. They cram all the money into the drive line and the exhaust is an afterthought. I paid about $500 bucks for my Jetthot headers; they have thick flanges, no exhaust leaks, no warping, they reduce heat, etc, etc, etc -- work great!
Will use ceramic from here on out...
Cheers,
Crunch
Old Jan 13, 2007 | 10:55 AM
  #34
rihwoods's Avatar
rihwoods
No cabin heat issues.....no A/C either...69 502...headers are 9 years old...
Rich
Old Jan 13, 2007 | 10:06 PM
  #35
petronix's Avatar
petronix
Is there any difference in underhood heat between using the stock manifolds versus regular headers?
My guess would be that the heavy stock manifolds would result in more heat under the hood.
Old Jan 13, 2007 | 10:13 PM
  #36
shafrs3's Avatar
shafrs3
They don't have as much surface area to radiate from.
Old Jan 13, 2007 | 11:29 PM
  #37
Ray Y's Avatar
Ray Y
What are you trying to compensate for with wrap?
If your wires are melting, why not shield them instead or use high temp teflon wiring? If the starter is locking out, why not use a mini with shielding cage? If it's cockpit heat transfer, why not use under carper barrier? If your paint is melting, well you have a big problem.
Ceramic is a true insulator, and the exterior only application is fine for thermal transfer abatement, i.e. space shuttle.
IMHO.
Old Jan 14, 2007 | 10:00 AM
  #38
Billysvette's Avatar
Billysvette
The reason for wrap is mainly for me cockpit heat.I have ceramic headers and they put out too much heat.I bought a set of super comp headers and im wrapping them.My floor where your fuel pedal is ,is too hot,after you drive for a while ,it gets really hot,uncomfortable,especially in the summer months.
