Distributor Install Help Needed...
Old Jan 10, 2007 | 09:27 PM
DO2G's Avatar
DO2G
Default Distributor Install Help Needed...
I am having trouble getting my distributor back in and aligned to the correct position.
Is possible I need to turn the oil pump shaft a little to allow the distributor to drop into the proper location?
The engine did move while the dist was out, but I did put it back to TDC.
Old Jan 10, 2007 | 09:53 PM
Merlinhaggard's Avatar
Merlinhaggard
Did you try turning the rotor when you slid it in?.
Old Jan 10, 2007 | 09:54 PM
DO2G's Avatar
DO2G
Yes, I can't get the rotor tip to point at my TDC mark
Old Jan 10, 2007 | 10:00 PM
rexx78's Avatar
rexx78
You need to turn the oil pump shaft. Use a long screwdriver.
Old Jan 10, 2007 | 10:10 PM
DO2G's Avatar
DO2G
Perfect.....Thank You
To Distributor Install Help Needed...
