Keisler Test Drive
Looking for some feedback...
Is this just aninitial break-in issue or do you think I am still not getting enough stroke on the master cylinder?
Shane
I have the TKO 600 in mine and it was very hard shifting at first, it will get much better after a few thousand miles. My only problem is I have to remember that I now have 5 gears instead of 4.
Russ
But why not ask Keisler directly?
Already corresponded thru PM.
The TKO is going to be a little "notchy" until the breakin period, roughly the first 500 miles or so. After that, it should shift like butter.
Richard
Tech Support
Keisler Engineering
Shane
2 things: First, it would not hurt to check the throw on the master cylinder to ensure you are getting the presrcibed amount of travel 1.5" however, I dont think this is an issue.
Second: My shifter was tight right out of the box, but loosened during the breakin period. What kind of fluid did you use? Keisler recommends either the $10qt synchromesh from GM or automatic trans fluid. Not knowing any better, I went with the auto trans fluid (cheaper) listed in the directions. Over time the shifter seemed to loosed and after breakin I changed the fluid to the GM synchromesh (after talking to Keisler about which fluid to use), and it seems to shift much smoother. I think the GM fluid and the breakin contributed to the smoother shifts.
In retrospect, I would have used the GM synchromesh in the first place.
I am glad you won the war! Nice job! You are in a for a treat -- totally new car!
Cheers,
Crunch
Cheers,
Crunch
The big now is I realize how much I need to change the rear gears from a 3.08 to a little bit better like a 3.55.
I have 3:55s and they are fine. However, after driving I think there is room for more gear --i.e., 3:73/3:90s. The reason I didnt change was because I had just changed from 3:08s to 3:55s about a year before I bought the 5-speed, and didnt feel like doing it again until I did some driving. $800 bills per gear change gets pricey, so I wanted to see first hand what the 3:55 felt like.
BTW, 4:11s require a whole new case, plus I think they would be too low.
Cheers,
Crunch
Cheers,
Crunch
At that price, I am assuming you had them rebuilt professionally? I think I am going to look at having VanSteel do it in a month or two. How bad was simply removintg the pumpkin?
Pumpkin removal is easy compared to installing a 5-speed-- just another round of sitting under the car and bumping you head, smashing fingers, and whatnot. I bet you could have it out in an hour or so.
Big things to remove:
Half Shafts,
Drive shaft
Rear spring (may want to remove shocks cause they may end up supporting the trailing arms otherwise)
I used my floor jack to support the pumpkin and unbloted it from the crossmember and lowered the jack. The crossmember can be a B&t^h to get out. Those bushings are tight and mine didnt want to budge w/o a hammer and pry bar.
The list of "while I was there" = 1. crossmember bushing kit (vette brakes) and 2. (I cant remember the name) the pumpkin housing support bushing -- it is round and you will see it towards the front yolk of the rear housing. How is that for a techincal explanation?
Cheers,
Crunch
Half Shafts,
Drive shaft
Cheers,
Crunch
The transmission is pretty much done now except I am waiting on a new bleeder screw, etc. I just have to figure out this rattle-like noise I get during test drives when I jump on the throttle. When cruising at any consistent speed or rpms seems fine...Only when I get on the gas. I am thinking / hoping it is the exhaust rattling as it had been welded to a bracket which was bolted to the cross member so I might try and welda newone today (fyi, I suck at welding).
Just a thought...
Crunch
I lengthened my clutch rod but I welded a 3/4" piece of rod in the middle of the turn buckle. I wish the turn buckle actually worked like a turn buckle...when you turn the body it will either lengthen or shorten via reverse threaded eyes. That would have made adjusting the lengh a lot easier. The maximum throw I could get on my cylinder is about 1.4". I adjusted mine with the carpet in place but only after I determined what my max travel was by bottoming out in the piston bore instead of the floor first.
I asked you in a previous post if you like your Quick Lift?
Good Luck.
