Front End Alignment Shims
Old Jan 11, 2007 | 07:50 PM
Tim81's Avatar
Tim81
Default Front End Alignment Shims
Hello to all,
I have yet another question for the forum. I am attempting a front end alignment at home. I have a 0 degree Camber on both wheels. I would like to adjust the Camber to about -.07 degrees. I'm not sure if I need to remove some shims or add them for a more negitive Camber. If I'm looking at the set up correctly I think I need to add about .250 thickness of shims to both sides and then adj the Caster as well. Thanks for any help or advice Tim
Old Jan 11, 2007 | 08:09 PM
Bob3700's Avatar
Bob3700
Default Camber Adjustment
What type of gauge are you using to adjust your camber and caster? Just curious as I have an older Bill Mitchell model that I really like.
In order to increase negative camber you have to move the upper a-arm in toward the centerline of the chassis. You add shims to both front and rear a-arm attach points.
For caster, you need to check the specs for manual vs PS. The manual will have a greater setting as you don't have the PS to assist the steering in returning to neutral.
The more caster you run, the harder it is to steer, BUT, the more stable the car is on the road. Wheel returns to neutral more readily.
HTH
Bob
Old Jan 11, 2007 | 08:50 PM
Tim81's Avatar
Tim81
HTH
Bob
Thanks Bob,
Thats what I thought I just am feeling a lack of confidence since this is my first attempt. The Gauge that I'm useing is a make shift angle finder that read out in degrees. Not sure how accurate it is, but I just want to get close. Your response will be very helpful to me Thanks Tim
To Front End Alignment Shims
