Fouled Plug
Old Oct 1, 2001 | 08:30 PM
dlw's Avatar
dlw
Default Fouled Plug
Right after returning from Carlisle my vette began missing so I decided to check the plugs and # 1 was fouled bad! Very black and full of gunk! I replace all the plugs and most looked normal. I just pulled #1 again and it was almost completly fouled again with less than a hundred miles. My question is this. Should I just check valve guides/seals on that one and keep my fingers crossed or should I bite the bullet and take the heads off and do a complete valve job just in case? Or is this the opportunity to upgrade. The heads only have a few thousand miles on them. (SR Torquers)
Thanks in advance :confused:
Old Oct 1, 2001 | 11:35 PM
Rocket Ron's Avatar
Rocket Ron
Default Re: Fouled Plug (dlw)
Do a compression test and hope its not bad rings.
Old Oct 2, 2001 | 12:02 AM
fireball's Avatar
fireball
How about the plug wire???
Old Oct 2, 2001 | 09:54 AM
Matt Gruber's Avatar
Matt Gruber
did you retorque the intake? COULD BE SUCKING OIL PAST THE GASKET
Old Oct 2, 2001 | 01:05 PM
Rob's 73's Avatar
Rob's 73
If you end up taking heads off, let me know. I would like to help for the learning experience. I plan on getting AFRs (180s or 190s) and putting them on this winter. I have never done the job before and love learning on someone elses dime.
Old Oct 2, 2001 | 03:18 PM
Steve Straus's Avatar
Steve Straus
Dan,
I have a compression tester if you need it. Give me a buzz when you plan on doing this.
Old Oct 2, 2001 | 10:01 PM
dlw's Avatar
dlw
Plug wires are OK. I havent run a compression check or re-torqued anything yet either. This just happened so I'm planning on a winter project with this. And a few other things of course. Thanks for the tips.
Steve, your on.
Steve's 73. Your more than welcome to watch. But if your watching me you wont learn anything.!!!!!!! :D :D
Old Oct 3, 2001 | 07:58 AM
Rob's 73's Avatar
Rob's 73
Say the word and I am ready to get my hands dirty. I have a home made leak-down tester if you need it.
:cheers:
Old Oct 3, 2001 | 05:21 PM
dlw's Avatar
dlw
Default Re: Fouled Plug (Rob's 73)
I'll get with Steve Straus and we;ll set something up. Shouldnt take long to check it out. I'll Send an E-mail to let you know.
Thanks, Dan
To Fouled Plug
