help w/ demon carb
Old Jan 12, 2007 | 04:58 PM
redc3's Avatar
redc3
Default help w/ demon carb
recently i asked about a float bowl adjuster leak. do i have to remove the entire bowl to fix the gasket under the adjuster? tried search and couldnt find any answers. thanks ahead of time
Old Jan 12, 2007 | 05:44 PM
b71vette's Avatar
b71vette
No - remove the retaining screw , the nut that adjusts the needle valve slides off and then you can replace the gaskets, believe there is one on each side of adjustment nut.
Old Jan 12, 2007 | 05:46 PM
TimAT's Avatar
TimAT
You are talking about the float adjustment? You can change the needle and seat by removing that screw/nut. Hold the nut, remove the screw from the needle & seat, take the nut off and replace the gasket.
You can also replace the needle & seat, and the o rings. Just remove the whole thing. Be careful- when you remove the whole thing, you have to readjust the float level. Too high and you could get gas all over.
Last edited by TimAT; Jan 12, 2007 at 10:54 PM. Reason: Ok I can spell, but my fingers can't
Old Jan 13, 2007 | 12:19 PM
redc3's Avatar
redc3
thanks ill try it today
To help w/ demon carb
