The rear spindle nut should be torqued to 100 ft lbs. I believe the front only require 12 ft lbs or so, depending on which bearing preload procedure you subscribe to.
Front. I torqued the nut, spun the rotor, then backed the nut off, spun, retorqued. Now the problem is that I can not get very close to 12 ft lbs and still line up the cotter pin with the hole thru the spindle.
So I went tighter. I am still feeling the play in it when I drive the car and jerk the wheel back and forth. I believe that only the outer bearings were replaced.
I guess I should take the hubs apart and replace all of them. I assume I need to take the calipers off?
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Re: Wheel bearing torque specs? (Rhys)
You don't need to rivet the rotor to the hub. They were rivetted together to ease assembly at the plant. Use a standard lug nut but with the flat side facing the rotor. Tighten three of these lugs to hold the rotor to the hub.
You might need to wiggle the rotor/hub assembly to push the outer bearings into their position. I didn't use the 12lb test---my installation is more of a "feel". I'd say the castle nut is tightened to about 20 ft/lb. then back off to the nearest opening.
Yes the caliper will need to be moved out of the way to remove the rotor.
The whole idea is to slowly torque the front wheel bearings to 12 foot-pounds while spinning the tire and wheel. If the cotter pin doesn't line up, LOOSEN the nut, do not tighten it! :eek: You can loosen it to the next flat and that will allow the cotter pin to go in. If you still have play you have a bearing problem on the inner or outer bearings. If you do replace them, always replace them as a set, including the races. This is not an area to go cheap on and always insist for US made bearings such as Timkin (sp?).
