Side pipes
Old Jan 13, 2007 | 02:51 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Side pipes
Does anyone know where to buy a set of side pipes that are nice but cheaper? I will take used if possible. I need them for my father's 68 with a 327. Are they also called lake pipes?
Old Jan 13, 2007 | 03:25 PM
The Spark's Avatar
The Spark
I think you mean "leg" pipes - as in they burn the heck out of your legs
Mine had chrome sidepipes when I got it. The seller said they were from JC Whitney. Try there.
There weren't too bad - except he mounted them BELOW the rocker panels. Talk about dragging them on every speedbump and driveway. It was too low. But it made it easy to remove the pipes.
Old Jan 13, 2007 | 03:30 PM
Big2Bird's Avatar
Big2Bird
Lake pipes are similar, but not the same.
http://www.thehotrodgirl.com/lakepipes.html
Old Jan 13, 2007 | 07:59 PM
stingraymaniac's Avatar
stingraymaniac
i have the patriot 4 into 1 style on mine i bought them from jegs
they cost 239$,looks and sounds great
here are a link:
http://www.jegs.com/webapp/wcs/store...52602_-1_11537
its the ones that are 63" long and have a outlet of 3 1/2"
i have some pics in this link:
http://www.garaget.org/?car=28452
here is a close up of the collector:
Old Jan 13, 2007 | 08:52 PM
Les 94 Comp Yellow's Avatar
Les 94 Comp Yellow
Default Lakes pipes ????
I guess it will take an old timer to answer this one. Lakes pipes were originally named after the exhaust pipes that ran along the outside of the care that would run at the Bonniville salt flats in Utah. the salt flats were lakes millions of years ago and are still called dry lake beds. There is where most of the land speed records were run. There are several other lakes that are used today also.
To Side pipes
