Rochester lean problem
Old Jan 13, 2007 | 05:26 PM
hensen1954's Avatar
hensen1954
Default Rochester lean problem
The carb I bought came off an unmodified car ( I think ) and my engine has heads, cam, open headers etc.
Even when warmed up I need to hold the choke plate nearly closed to make the mixture richer.
As its still a 350, anyone got any ideas about what jets I should be looking for ??
Old Jan 13, 2007 | 06:01 PM
eole's Avatar
eole
are the idle mixture screws turned out enough?
are the holes from the mixture screws blocked?
fuel filter dirty?
fuel pump broken?
maybe a lot, what is the engine doing?
Old Jan 13, 2007 | 07:30 PM
justanotherdoe's Avatar
justanotherdoe
Here is a link to lars' qjet tuning paper:
http://www.corvettefaq.com/c3/QJetTuningPaper.doc
It should tell you everything you need to know.
To Rochester lean problem
