SBC build-up
Old Jan 13, 2007 | 11:00 PM
bbeck's Avatar
bbeck
Default SBC build-up
Here's the current set-up:
283 Block bored .120
Stock crank balanced and chamferred
Pink rods reconditioned, polished and balanced
Badger pistons- checking on size also balanced
74 cc chevy heads with 2.02/1.60 valves
and an old Weiand dual quad intake
running two carter 600s
used to run 64cc "camelhump" heads.
with the 64cc heads, the motor used to run 10.6s quarters in a 65 nova. but, over time the studs started to pull on the 64 cc heads.
and that led to tunning the camelhump heads.
I'm trying to find the cam card, but it's a 534 lift cam according to my dad's memory.
The car runs cam2 and is only for weekend cruising/playing around.
We're trying to decide on some nice aftermarket aluminum heads, and having a hard time making a decision. Neither of us have any experience with aftermarket heads, and I know you guys would have good suggestions/ experience. the budget is prob up to around $1500. If I find any more info- the cam or pistons, I'll post it.
Old Jan 13, 2007 | 11:05 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
AFR Eliminator 180s or 195s. Nice things are often said about Brodix, but I think the AFRs flow the most, right now. You can put 7/16" screw-ins in this head, even though AFR only sells them with 3/8". Or you could go with a Jesel shaft system to spread the load.
Old Jan 13, 2007 | 11:53 PM
bbeck's Avatar
bbeck
I imagine that the 3/8 would probably be fine. we could give it a try anyway. where would be a good place to pick these up? what's a good price?
Old Jan 14, 2007 | 10:09 AM
bbeck's Avatar
bbeck
anybody else have any suggestions?
Old Jan 14, 2007 | 10:14 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
AFR is the way to go! Buy factory direct. Tell them what you got and they will sell you what you need!
Old Jan 14, 2007 | 10:16 AM
Billysvette's Avatar
Billysvette
Afr are the best ,these guys tell you truth.cant go wrong with them,i have them on my other vehicle.The other heads are nice too,edelbrock,brodix,trickflow,dart,all compareable.But i think afr edges them out.
Old Jan 14, 2007 | 10:45 AM
bbeck's Avatar
bbeck
who's using these, and what kind of #'s are you getting?
To SBC build-up
