tri-power 2nd vacuum pod connection ?
Old Jan 18, 2007 | 03:32 PM
Tom454's Avatar
Tom454
Sure, I'll part with the picture.
Old Jan 20, 2007 | 04:05 PM
Solid LT1's Avatar
Solid LT1
The carbs you have have been "modded" by some genius. I used to Drag Race a 440 Six Pack Mopar, I think all 2300 3X2bbl Holley set-ups have 2 ports from the vacuum diaphram of the secondary carbs to the main body. One port is the vacuum source to open the throttle blades, the second (smaller) port is a "bleed" to allow the closing of the throttles to occur. I had great difficulty with my Mopar Tr-Power before the Super Stock racer Paul Rossi showed me how you plug off the bleed ports and install a real heavy return spring on the 2300 outboard carb mechanical return linkage to improve low RPM throttle response and earlier opening (I already had the lightest Holley springs in my carbs and was getting very frustrated with my set-up.) With Rossi's help my "6 Pack" became a 11 second strip terror to be respected (all on 9inch wide slicks.) Holley will sell 2300 diaphram housings to you if you want to replace them.
Old Jan 22, 2007 | 07:19 AM
Tom454's Avatar
Tom454
The GM Factory Tripower outboard carbs only have one passage connecting the vac can to the main body.
Old Jan 22, 2007 | 02:47 PM
Wrencher's Avatar
Wrencher
hcabplanalp@ucdavis.edu
Old Jan 22, 2007 | 03:13 PM
WESCH's Avatar
WESCH
Hi
I took all 3 carbs apart , installed the rebuild kits and reassembled the correct way. The Vacuum pods should now be correctly connected and I hope, it will work fine.
How do this carb dates be read ?
Aft carb LIST 3659 , 1917
Fwd carb LIST 3659 , 1917
ctr carb LIST 4055-1 , 1647
I also found the primary jet sizes to be 63 and the 2nadry jet size plate to be -3.
Hope that is correct for the 435 HP setup.
Günther
Old Jan 22, 2007 | 04:02 PM
Tom454's Avatar
Tom454
Is this what you have?
3902356-EU
LIST-3659
873
3940929-EV
LIST-4055-1
8A2
3920359-EU
LIST-3659
873
63 is correct for the 4055-1 (manual tranny)
61 is for 4056-1 (automatic)
-3 sounds familiar ... I'll have to check my spreadsheet on that.
Old Jan 22, 2007 | 07:34 PM
Tom454's Avatar
Tom454
Hans.... you have mail.
Gunther.... you have mail.
The secondary metering plate is 34R-5113-3.
Holley discontinued the original a long time ago, but I had a commercial account directly with Holley and after many conversations with their techs, it was agreed that the 34R-5113-3 was the correct part.
Old Jan 23, 2007 | 03:28 AM
WESCH's Avatar
WESCH
Hi
This is what I have :
Both 2ndaries are :
3902353 EU
LIST 3659
1917
Primary is:
3940929-EV
LIST 4055-1
1647
I thought that the last 4 digit codes are the date, can't find any code with letters.
Thanks to your info I got by mail, at least it is confirmed that I have a late 69 setup for 435 HP manual with original primary and 2ndary jets.
Just wondering about the date codes.
Günther
Günther
Old Jan 23, 2007 | 08:46 AM
Tom454's Avatar
Tom454
LIST 3659
1917= 191st day of 1977 (Julian date plus year)
LIST 4055-1
1647= 164th day of 1977
I suspect these are replacement carburetors.
Old Jan 23, 2007 | 01:00 PM
WESCH's Avatar
WESCH
Hi
So for sure 1977 and not 1967 ?
I thought replacement carbs are not dated ?
Günther
Old Jan 23, 2007 | 01:25 PM
Tom454's Avatar
Tom454
Up to about 1972 they had a 3 digit date code.
Later they went to Julian day plus year.... 4 digit.
Look here...
http://www.chevellestuff.com/generic/holley_carbs.htm
Old Jan 23, 2007 | 02:47 PM
WESCH's Avatar
WESCH
Rgds. Günther
