Water Pump Dowel?
Old Jan 14, 2007 | 08:36 AM
DO2G's Avatar
DO2G
Default Water Pump Dowel?
I just bought a new AC Declo water pump and in the box was little 3/4" metal dowel. What is it used for? Do I need to use?
Old Jan 14, 2007 | 05:35 PM
DO2G's Avatar
DO2G
Ttt
Old Jan 14, 2007 | 05:53 PM
Jims73SF's Avatar
Jims73SF
Default Metal Dowel?
Was it solid? With threads or without?
If it was solid without threads, I have no idea.
A heater hose nipple connects to the passenger side, that's a 3/4" fitting, but hollow with threads on one end and a ridge for the hose to slip over on the other.
There is also a solid plug that goes on top of the pump. The one on the pump I took off a couple weeks ago had 1" outside diameter threads, the one I needed for the new Stewart stage 2 I got was a 3/4" plug.
Old Jan 14, 2007 | 06:03 PM
DO2G's Avatar
DO2G
solid with no threads....3/4" long and 3/16" diameter.
Old Jan 14, 2007 | 06:14 PM
Jims73SF's Avatar
Jims73SF
Default wow
ok I have no idea.
I thought it was 3/4" dia.
The Stewart I bought came with a (let's say) 3/16 threaded stud (so its adjustable) about 2 inches long to go through a hole to line up with the cam if you have a need to restrain the cam.
Is there a pocket on the block side of the pump that this would fit into?
To maybe apply pressure to the timing chain cover at the cam? Thats a long shot, but all I can come up with. My stock WP didn't have anything like that when I took it off.
Old Jan 14, 2007 | 07:49 PM
DO2G's Avatar
DO2G
There is a spot right below the right side lower water pump mounting hole. Maybe it is used for alignment to assist with installation?
You can see it here next to the pipe plug.
http://www.ecklers.com/product.asp?p...dept%5Fid=1259
Old Jan 14, 2007 | 07:57 PM
rponfick's Avatar
rponfick
I posted a similar thread a few months ago and never got a answer. My pump was from Napa. Nobody seemed to know what it was for, so I just left it in the box. It must have some purpose to be included, but it seem strange that no instructions or person knows what it is for. What a deal.
Ralph.
Old Jan 14, 2007 | 08:26 PM
Jims73SF's Avatar
Jims73SF
Alright, it just occurred to me...
MAYBE it is to align the holes in the gaskets with the holes in the block so that when the sealer you use dries enough to stick to the block, the gasket isn't in the way of the mounting bolts.
I know I ran into a problem with trying to get both sides lined up (without a gasket sliding around on one side or the other and blocking the mounting bolt) with the sealer still wet on the block and the pump.
(The picture of it next to the gasket in the link you posted gave me that idea.)
...and with that, I'm out of ideas.
Old Jan 14, 2007 | 08:39 PM
rponfick's Avatar
rponfick
Jim, I think you are on a stretch.
When has a manufacturer thought of your ease in mounting a gasket enough to include a dowel to index the mounting?
Somebody out there must know what this dowel if for?
But, Jim, your explaination is as good as anything suggested.
Since it fits in the hole next to the bolt mounting hole, I thought maybe it was a plug to prevent coolant from bypassing the thermostat, but it is not in the right place. I give up.
Ralph.
Old Jan 14, 2007 | 08:44 PM
Binnie77's Avatar
Binnie77
I just bought a new Edelbrock aluminum pump and there was a dowl pin with it as well. Like everyone else I didn't know what it was for.
Old Jan 14, 2007 | 09:59 PM
noonie's Avatar
noonie
I'm surprised no one has answered this before.
The dowel supplied is to block off the water pump bypass which is on all stock water pumps.
This bypass circulates coolant until the tstat opens, so as not to create engine hotspots and pump cavitation. Some people tap this hole in the block and screw in a brass allen socket pipe plug instead of the dowel.
Some aftemarket high performance pumps do not have bypass flow built into them. This is based on the theory that more flow will occur without the bypass for better high performance cooling.
If you use the dowel, then you must drill a few 3/16" holes in the tstat so that there will be a small amount of flow.
These holes serve 2 purposes, 1 for burping the air out while filling the system and 2-for creating necessary flow until the tstat opens. It also can be argued that the tstat will be more responsive at intitial warmup with the holes.
BTW Jims73SF
Good choice on pump!
Old Jan 14, 2007 | 10:11 PM
Fevre's Avatar
Fevre
Might be for pulley alignment, here is a Mitsibish pump for sale on e-bay, you can see the hole in the face where the dowel would go
This Water Pump Includes Dowl Pin for Pulley Instalation
http://cgi.ebay.com/ebaymotors/JDM-4...QQcmdZViewItem
Old Jan 15, 2007 | 10:48 AM
rponfick's Avatar
rponfick
Noonie, thanks for the explaination. I am also surprised this subject is so uninformed. You'd think there would be some explaination included in the pump packaging. I consider myself fairly knowledgeable, but certainly ignorant on this subject.
I guess I am still a little dense, but why would someone plug this hole with the dowel. Is it just like you explain that some think cooling flow is better without the hole? It seems dangerous that the dowel is included and no explaination that holes need to be drilled in the thermostat to compensate for the lost flow if dowel is used.
Thanks again, Ralph.
Old Jan 20, 2018 | 02:40 PM
Jcpstrat's Avatar
Jcpstrat
Just thought I'd post a link to what that is essentially what "noonie" above said.
https://www.flowkoolerwaterpumps.com...duct_info.html
Was wonder myself what this metal dowel was for as I'm installing a new water pump and found this post.
Old Jan 20, 2018 | 07:10 PM
george2066's Avatar
george2066
Default the next question
dry or some sealant on the gaskets
went dry the last time because felpro says DRY, so far so good
chase those threads into the block
Old Jan 20, 2018 | 07:27 PM
HeadsU.P.'s Avatar
HeadsU.P.
Permatex makes a RTV specific for: Waterpump & Waterneck gaskets. Small tube, not much for the money, found at AutoZone. Works really, really well for glycol situations.
To Water Pump Dowel?
