Spark plug questions
Old Oct 2, 2001 | 02:38 AM
BAD-L88's Avatar
BAD-L88
Default Spark plug questions
Looking at original spec sheets for my car it says use AC 43 XL or AC R 43 XL
I see Ecklers has an AC R 43 XLS listed, is this suitable?
Also, I recall some tal on the board about AC 44's, where do they fit into the picture?
Finally, can someone tell me their experience/opinion of AC rapid fire plugs?
Old Oct 2, 2001 | 03:57 AM
Chuck H.'s Avatar
Chuck H.
Default Re: Spark plug questions (BAD-L88)
I use rapidfires.
Seemingly smoother idle and power.
Worth 4x the price. Probably not. :smash: :smash:
Old Oct 2, 2001 | 04:50 AM
marky mark's Avatar
marky mark
Default Re: Spark plug questions (Chuck H.)
A/C R44XLS is slightly hotter than R43, R42,etc. The XLS part means they can be used in aluminum heads, as well as cast iron heads. Gap is standard at .035.
I think that the L-88 motor called for the R-42 plug or perhaps the R-43. You could experiment with both. I've tried the R-43 on my 427 L-36 and went back to the R-44XLS which is a good, all around plug.
I intend on trying the Rapid Fire plugs also. I think the "4" version would be a similar heat range to the 44. Also, I've read that they come standard with the new 502 crate motors.
Good luck, mark :flag :chevy
To Spark plug questions
