Sandblasting the frame...what
Old Jan 14, 2007 | 06:42 PM
Rich72's Avatar
Rich72
Default Sandblasting the frame...what
What type of media did you use?
Old Jan 14, 2007 | 07:55 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
I would probably use aluminum oxide.
Old Jan 15, 2007 | 10:02 AM
Rich72's Avatar
Rich72
I thinking sand for the frame and aluminum oxide for the suspension parts.
Seems the blasting sand is harder to find than any other type of media.
Old Jan 15, 2007 | 10:12 AM
Twin_Turbo's Avatar
Twin_Turbo
sand = silicosis and the AlOx embeds in the metal giving a little more corrosion resistance right after b;lasting.
Old Jan 15, 2007 | 10:16 AM
J. Swisher's Avatar
J. Swisher
Black Beauty worked well to clean everything up, picked it up at the local home improvement type store. Product seems to have a few different names Black Diamond is another name that I've seen it called
Old Jan 15, 2007 | 11:54 AM
markdtn's Avatar
markdtn
When i started mine I bought Sandblasting sand at Home Depot, then nobody carried it anymore so I switched to playground sand and screened it. Worked great, just slow.
Old Jan 15, 2007 | 12:14 PM
celeryman22's Avatar
celeryman22
I would use whatever you can find. Here where I am aluminum oxide sells for 50.00 a 55lb bag. Thats expensive, white lightning is about 10bucks a bag.
There are many types of abrasives to use. I would stay away from the Silica based products and go with something a bit more "safer".
Black magic, black lightning, black beauty, crushed glass, white lightning, green lightning, any of these will work just fine.
Mike
Old Jan 15, 2007 | 04:17 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
Black Beauty $6.75 100 pound bag.
Old Jan 15, 2007 | 06:20 PM
Scott Marzahl's Avatar
Scott Marzahl
I've used both 70 grit sand and 35 grit black Beauty. I found that the finer material was much better and I used a lot less of it. I would try to find 60-70 grit black beauty if you are concerned with sand.
Old Jan 15, 2007 | 08:16 PM
Rich72's Avatar
Rich72
Where did you find it?
Old Jan 15, 2007 | 08:55 PM
79VetOwner's Avatar
79VetOwner
I used glass bead on mine. It worked great. Some processes use sand and then glass bead to polish it up a lot better. I just used glass in my garage so I could sweep it back up and reuse it. Worked great.
Old Jan 15, 2007 | 09:00 PM
BLACK SHARK
At the local hardware store. They keep 2-3 palets of it. That $$$ all the time around here.
Old Jan 15, 2007 | 10:35 PM
shafrs3's Avatar
shafrs3
$2.00 a bag play sand from Lowes.
To Sandblasting the frame...what
