Head Lamp Relay Valve
Old Feb 2, 2007 | 07:43 PM
toddalin's Avatar
toddalin
I've got a set that I took off of my '70 in boxes on the shelf. They are ORIGINAL (i.e., right top pattern) and certainly worked when I took them off some years ago.
If your interested, let me know.
Old Feb 2, 2007 | 07:46 PM
Duke94's Avatar
Duke94
Originally Posted by Jc3vette
Does anyone have a recommendation on where to buy a good head lamp relay valve? I purchase one from corvette central about a year ago and rarely drive at night. When vacuum is applied to the yellow port and the green port is blocked it will not maintain vacuum pressure it leaks out of the bottom/filter. Too much money for the amount of times it has been used. Any recommendation would be appreciated.
ZIP sells as actual GM replacement (ain't cheap at over 100 bucks!). I have found that the made in China repo everyone is selling for 39-59 bucks are junk. I've had to send numerous ones back because they leak. Finially bought a GM replacement and it worked fine. Most all the eBay ones are inported.
Old Apr 19, 2007 | 02:35 PM
ram100987's Avatar
ram100987
Originally Posted by PhotoVette1
I have been using 3-way solenoid air valves for over four years--they work perfect.
Why use cheap plastic when you can have stainless steel?!
All I did to install them was to buy the right size hose nipples at Home Depot (easy.)
Hook up the ground wire and attach the hot wires to the high/low beam wire with a relay:
This makes the operation automatic--the headlights come on and the 3-way valve energizes.
You can find 3-way 12vdc air valves on ebay all the time. $15-20.
You need two of them.
http://cgi.ebay.com/asco-joucomatic-...QQcmdZViewItem
Could you post some more info on this?!!? I've already sent you a PM.
Both of my relays are leaking. I only have one hooked up right now and im losing about 6 PSI of total manifold vacuum from it. so I am VERY interested in the setup to fix this leak issue and also to elimate a bit of potential leaks
Old Apr 19, 2007 | 04:22 PM
68 NJConv 454's Avatar
68 NJConv 454
I can only afford the repro valves but seeing as how they are piece of junk to begin with I won't bother. So I've been researching converting to electric firebird motors for the headlamps eliminating the vacume system which would be my ideal solution but again, that is expensive and I have a wiper door to contend with. The 3 way solenoid method sounds good to me. Would love to see pics and more info on this.
Something like this work also? (i know nothing about electricity)
http://cgi.ebay.com/New-miniature-pn...QQcmdZViewItem
