Internally or Externally balanced engine?
Old Jan 15, 2007 | 09:29 AM
cduemig's Avatar
cduemig
Default Internally or Externally balanced engine?
I bought a 383 crate motor awhile back and I'm getting ready to drop it in when I realized that my flexplate won't work with the torque converter I bought (10.75 vice the 11.5") I got the flexplate from my uncle and at the time never thought about engine balance as I knew nothing of this. I have no idea whether my engine is internally or externally balanced. Unfortunately I can't ask the builder so I'm in a small pickle. It did not come with a flexplate, but I assume that the 383 rotating assembly to be internally balanced. Is there any way I can tell for sure?
Old Jan 15, 2007 | 09:32 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Check your balancers part number against the manufacturers website.
Old Jan 15, 2007 | 09:50 AM
gerry72's Avatar
gerry72
Unless this is a forged high-end build, it will very likely be external balance. Very few 383 builds are internal. If it came with a damper, you can look for an imbalance weight on the back of the balancer on the inside. You could also pull the pan and look for Mallory metal slugs welded to the crank counterweights.
To Internally or Externally balanced engine?
