Electric Choke Connector Big Problem
Old Jan 15, 2007 | 01:49 PM
empotoma's Avatar
empotoma
Default Electric Choke Connector Big Problem
I broke the brass connection blade off of my electric choke!!! The original female connector on the wire had been replaced with a crimp on piece. I pressed down on it while replacing the choke pull off.
So, I was replacing a part with 2 screws.. now, I'm just screwed.
Is there any way to fix this? ( And not break something else in the process)
Ed
Old Jan 15, 2007 | 02:04 PM
marshrat99's Avatar
marshrat99
Is there enough metal or wire left such that you could solder a piece of wire onto it? Also, I suppose you might be able to disassemble and rework that way.
Old Jan 15, 2007 | 02:13 PM
empotoma's Avatar
empotoma
Thanks for response. Solder is no problem, but the question would be how to remove the part to solder a new connector. This unit has the riveted in place feature. If I can figure out how to drill out those rivets will the part come off so that I can work on it ?
Man.. I still can't believe I broke it!!
Ed
Old Jan 15, 2007 | 03:07 PM
marshrat99's Avatar
marshrat99
Maybe some would consider this Bubba, but I'd drill off the heads of the rivets. To reassemble I'd use epoxy. I swear epoxy rates right up there with duct tape and ball peen hammers.
Old Jan 15, 2007 | 09:48 PM
Big2Bird's Avatar
Big2Bird
Drill out the rivets. Get new part from NAPA. Should come with screws and clamps. Rivet holes may already be threaded. Tap if not.
Old Jan 16, 2007 | 08:02 AM
DaveL82's Avatar
DaveL82
The choke element and plastic housing should be about $30 from most parts stores or as someone mentioned pull the housing off and solder a wire to it and put a connector on the wire.
You use a drill to drill off the rivet heads (3/16 bit I think). Once the rivet head is off use a small punch to tap the rivet body through the choke casting. To re-attach use small sheet metal/self tapping screws. I forget the size of the screws and they should only be big enough to cut a thread without too much force. If you replace the element assy it may come with screws.
Old Jan 16, 2007 | 12:16 PM
empotoma's Avatar
empotoma
Seeing as I have to take it apart regardless, I'll see if soldrering is an option before I do anything else. Chances are I'll just get the new part anyway.
Thank you all for your help!
Ed
Old Jan 16, 2007 | 03:55 PM
lars's Avatar
lars
Just replace it. You can get the entire GM-style choke assembly with the GM-style electrical connector from Edelbrock. Don't bubba it or try to solder when you can get the right part brand new. It's about $33 though Summit, part number EDL-1932..
To Electric Choke Connector Big Problem
