Transmission Change
Old Jan 16, 2007 | 01:56 PM
whitesnake81's Avatar
whitesnake81
Default Transmission Change
What parts are needed to change over from and Automatic Transmission to a Manual 4 speed, on a 73? Can any of the parts be used from other cars other than a Vette, if so which ones? Will it be hard to change over?
THANKS FOR YOUR HELP!!
Old Jan 16, 2007 | 10:17 PM
birdsmith's Avatar
birdsmith
I did my '70 last spring, can't be much different than your '73. I have a comprehensive list of everything needed to complete the job and how much it cost...email me and I'll send it to you.
Old Jan 16, 2007 | 10:59 PM
KunkFunk's Avatar
KunkFunk
can you give a price range cause im also looking to do that for my 79
Old Jan 17, 2007 | 05:47 AM
jotto's Avatar
jotto
Could you post it here? Always good to have some idea whats involved work and cost wise.
TIA.
Old Jan 17, 2007 | 09:22 AM
Durango_Boy's Avatar
Durango_Boy
TIA.
Posting here would be great for all the people that ask this question...which seems to be several times a month.
Old Jan 17, 2007 | 10:19 AM
redvetracr's Avatar
redvetracr
I have an extra pedal assembly and some extra clutch linkage in very nice condition if anyone is interested...e-mail DIRECT!! redvetracr@yahoo.com
Old Jan 17, 2007 | 12:39 PM
BerniesVette's Avatar
BerniesVette
Why go with a 4 speed when you can install a 5 speed for the same money and have a better tranny with better top end and gas mileage. My auto to 5 speed swap cost me less than $1,500.00.
Bernie
Old Jan 17, 2007 | 09:14 PM
KunkFunk's Avatar
KunkFunk
thanks for the tip im ganan make the switch during the summer time
Old Jan 27, 2007 | 01:11 PM
Durango_Boy
redvetracr - You have email.
Old Jan 27, 2007 | 01:28 PM
Binnie77's Avatar
Binnie77
500 miles ago I converted my '77 from auto to TKO-500 and originally installed a mechanical linkage. I have now just converted my manual linkage system to hydraulic. If anyone is looking for a complete manual linkage system which is like new, I have all the parts. I also have a 168 tooth billeted steel flywheel with less than 500 miles on it as I just switched engines from the L-48 to ZZ4 and I had to buy a different flywheel. IM me if you are interested.
Old Jan 27, 2007 | 01:36 PM
Durango_Boy
How do you like the hydraulic over the manual?
Old Jan 27, 2007 | 01:38 PM
Binnie77's Avatar
Binnie77
I have not been able to test drive it yet as I have run into a clearance issue with my hydraulic bearing. I am awaiting a response from the supplier of the kit as to the fix.
Old Jan 27, 2007 | 01:45 PM
Durango_Boy
Is that a problem isolated with your transmission brand or all C3s could have this issue?
Old Jan 27, 2007 | 02:19 PM
BerniesVette
You must have gone with a hydraulic throwout bearing. Pricey. For about a $100.00 you could have installed a hyd slave cyl to the clutch fork and been driving now!
Bernie
Old Jan 27, 2007 | 02:21 PM
Durango_Boy
Bernie
C'mon caveman...not everyone stayed at a Holiday Inn last night.
Old Jan 27, 2007 | 03:40 PM
Binnie77's Avatar
Binnie77
I would like to have a 1/4" free play in the hydraulic bearing in it compressed state between the pressure plate forks and the bearing surface. Right now I have -1/4" so I need to gain 1/2" some how and I don't see any easy way to do that.
Old Jan 27, 2007 | 05:58 PM
BerniesVette
Did you get the throwout kit from the people that you got your TKO from? They should have sent you everything your need and instructions on how to get the 1/4 clearance you need. If you can't you can always sent it back and do it the easy and cheap way. Don't get rid of the flywheel until you get it how you want it!
Caveman, er Bernie
To Transmission Change
Old Jan 27, 2007 | 06:59 PM
Durango_Boy
I didn't think of that...if it was a vendor purchase, they will or should have everything you need in the kit, and tech support. Maybe contact them.
Old Jan 27, 2007 | 07:16 PM
Binnie77's Avatar
Binnie77
Yes, they have excellent customer support and I will be in touch with them on Monday.
Old Jan 27, 2007 | 07:17 PM
Durango_Boy
Places like that may even have people on the phones on the weekends.
