I need help. Removing the bottom seat frames (the plastic that the seat pads fasten to). Four bolts hold the frame down. I've got the two closest to the front of the car.
How do I access the two in the rear? I see a small circle that looks like an access hole. Is their an odd wrench I might need?
I should mention both seat sliders are broken. Even if I could slide the seats all the way foward, I must be missing something in my ignorance.
If the seat won't slide forward, getting to the 2 rear bolts will be more difficult. It's just 2 more bolts like the front two. Can you reach under the seal to pull the adjuster lock open so it will move forward? The bolts are just covered by the carpet flap. Can you see the bolt at all or is the seat all the way back?
