I have been thinking of replacing my 400 trans with a 200r4 someday. I opened the local classifieds today and someone has a "TCI 700R4" transmission and converter from 1989 Firebird Formula TPI 350 for sale.
Can anyone offer some advise as to this would be a suitable replacement?
Yes, probably. If you buy a 700R4 you want an '88 up core. I would verify the date on the main case. There are plenty of posts detailing the swap and pros and cons of 700R4s. If you use an F-body transmission you may have to use a different tailhousing with a mount if you use the stock crossmember. If you use a BowTie (or similar) crossmember, you can keep the F-body tail.
It'll work fine. At a minimum though I'd suggest taking the pan off and checking for any metal filings etc. Fabricating the mount really isn't that hard. The driveshaft will need to be shortened and all the usual tranny swap stuff. Do a search and you should find lots of info. An OD is well worth the effort.
Any help would be appreciated
Bill
That would be a great choice. Rebuild it with a Corvette Servo. Good to go.
In actually later '87 on up they went to another aux valve body in the castings, and it did something I forget what, to increase reliability....
supposedly....I not a fan of the 700 and if you go to the various builder sites and see the list of possible 'fixes for the 3/4 clutch pack repeated failures, and the prices of what they call 'shells' and so forth, they are notorious weak spots.....
buy a 200 4r and have done with it....much easier....
The first 3 months of production during the 87 model year was non aux valve body. Aux vb versions are not really desirable because of the aux vb. It was the other improvements that did it. The non aux models used a turbo 350 (smaller) lo-roller clutch. The wider one was use in the aux vb models. The other goodies are:
10 vane pump
better reverse apply package
28 element forward sprag
much simpler....
fits better and lighter weight.....
thicker output shaft to correct them from snapping in two
hayman,
I understand that the 200R4 is the same length as the T400 and you don't have to change the crossmember if going from a 400 to a 200 as the mounts are almost in the same place. I'd have a good trans shop go through it before fitting and have a shift kit fitted. The shop should know which parts are weak and need replacing.
If you buy the 700, you will have to do a lot more fabricating to make it fit. I own a '74 with a T400 and would like to fit an OD trans, and given a choice, I'd go for a 200.
